Question about LG WM3988HWA Front Load Washer / Dryer
Lg f14a8yd beeps not working
When machine is turned on it should play a little tune. it does not. neither does it at the end of a wash or dry cycle. when you press any of the buttons is should emit a beep which again it does not
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
SOURCE: my lg fuzzy logic wf s6607tc water level indicator
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
Posted on Jan 11, 2010
SOURCE: I just had the LG
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Posted on Jan 03, 2011
LG WT5101HW - Machine won't turn on. Just plays the tune softly when pressing power button. Also, machine have not been draining properly lately. Turns off by itself mid-drain with DR error code.
DR is a drain error. Have a look to see if the drain filter is blocked (if fitted) or if there is an obstruction or blockage in the pump or drain hose. If it cant pump out, the machine will stop during the cycle.
Mar 29, 2016 | LG Washing Machines
Wash down
Since down comforters are very light in weight, they confuse energy efficient front loader washing machines in how much water to add. Therefore, very little water is used, which results in a semi-damp comforter at the end of a wash. Pre-soaking the comforter beforehand would help, however, now the comforter weighs a ton, and the machine will vibrate like crazy during a spin cycle. It may be better to have the comforter dry cleaned.
Apr 28, 2014 | LG WM1812C Front Load Washer
How do you turn off the beep at end of washing machine cycle? Thank you.
Press and hold the Stain Guide button for 5 seconds. Choose Machine settings then choose End of Washing Cycle Beep and change to disable.
Jan 08, 2011 | Westinghouse Washing Machines
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine - LG TROMM - door is not opening
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............I'll be back with a further post
Mar 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Zanussi ZWF16581W Washing Machine
I believe there is a setting where you can turn the beeping alarm off completely. Read the manual and you should find it.
Mar 04, 2008 | Washing Machines
Open Questions:
LG WM3988HWA Front Load Washer / Dryer Logo
64 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
