Question about Gateway Computers & Internet
Envision monitor model #H190L will bad capacitors in the power supply cause the power light to not light
Will bad capacitors in the power sully cause the power on light not to be on?
  • Gateway Master
  • 3,320 Answers
Possibly.
Posted on Mar 28, 2014
map9966
  • 2351 Answers
SOURCE: envision model H190L ser#91077CA000122 cannot change resolution
Mac's a bit differant than windows. To change your screen resolution first change the monitors refresh rate to something like 75 hertz. Than you can change the Screen resolution. Thats how it is done on a windows machine. Than again your Mac might need a video card software update.
Posted on Feb 05, 2008
  • 3 Answers
SOURCE: Capacitors??? WOMAN NEEDS HELP PLEASE!!!???
The term: "it has no power" is not specific enough. If the actual led indicator light on the front of the monitor lights up with a green color, then goes out or starts flashing, then maybe, perhaps the problem with the monitor is that the high voltage power supply for the screen backlights is not working. The common components that fail are the capacitors on the high voltage power supply board. If the capacitors are swollen or leaking, they are probably bad. You must replace a capacitor with the exact size of capacitance. You cannot replace with a "stronger" capacitor. You can replace with a higher temperature rated capacitor, if the capacitor will fit in the alloted space on the circuit board and in the case.
Posted on Aug 06, 2008
kd6rhd56
  • 400 Answers
SOURCE: envision 17" model 1710e monitor blinks on and off
You need a technical service manual/with schematic for that model an is only available at the Manufacturer website.
Posted on Jul 11, 2009
  • 541 Answers
SOURCE: I plugged in an Envision
what happens when you plug the other monitor in? usallay black screen is bad inverotr or power supply.
Posted on Dec 26, 2009
Geekman
  • 32281 Answers
SOURCE: what kind of capacitor does a samsung 906bw lcd
There capacitors would most likely be electrolytic type. They are polarized capacitors and used for filtering DC voltage supply to remove the ripply and smooth the DC power.
If you cannot get a 10 volt capacitor then you can use a higher voltage type provided it can fit on the circuit board.
Posted on Mar 29, 2010
G218a1
check power and also check the capacitors on the power supply because this is a common symptom of a power supply with bad capacitors on it from heating up.
Jul 03, 2014 | Envision Computers & Internet
Power problem
Probably the power supply is failing.
Sep 02, 2012 | Envision H190L Monitor
Monitor turns on but black sceen and it puts up a message that says Out of Frequency
There are 2 possible solutions and the first one is that you need to cut down your resolution in your settings.
1. Right click on background screen
2click settings tab
3. Go to bottom left and move the arrow leftand clicck apply
This may fix it.
The next thing is thatsome of the capacittors on your power supply may be bad and need to be replaced.
Feb 16, 2011 | Envision H190L Monitor
We have an Envision H190L Wide screen LCD monitor. We always shut down the screen after each use. The screen just went black and will ot turn on. I've disconnected the cable and plug and reconnected with...
3 years old is about the right time for the caps in the power supply to fail, that will be the first place to look, it can also be the backlight inverter circuits or worst case will be the lamp assmblies.
Read an see the pictures here:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 28, 2010 | Envision H190L Monitor
Power button locked, to unlock...
You may wish to try this (my model AOC g2016wa2)
1. push MENU button
2. scroll to Advanced
3. push MENU button
4. scroll to Factory recall
5. push MENU button
It resets the power button locked setting but you lose all other settings.
Feb 24, 2010 | Envision H190L Monitor
I plugged in an Envision Monitor, H190L, to my HP Pavillion a1020n. I get No Signal and then a blank screen. How do I fix this?
Hi
Often there is noting wrong with the display, in most cases the problem is with the computer.
Try the monitor in both of the display outputs your system has, some machines only have one.
If the monitor remains blank on both cases and it works in another computer, then the issue is quite clear that your hp pavilion is not starting up properly, possibly the display adapter has stopped working or similar.
Do you get any beeps from the computer? Have you done any changes to the machine recently? have you tried any other displays with the machine?
If you are in warranty you should get in touch with hp directly to avoid voiding your warranty and get the machine fixed.
If you are outside of warranty, the machine needs to be tested at a professional to confirm the cause of the problem.
Let me know if you need further assistance or if you would like to open up the case of the computer and do some testing. I would expect that you have some experience and know what parts are what, if you don't know anything about the internals of the computer it might be best to just take it to a professional.
Dec 25, 2009 | Envision H190L Monitor
Blink s blue light envision g218a
The blinking blue light indicates your power supply has blown out. The heat buildup in the case has caused parts called capacitors to blow and short the power supply causing the blinking. We offer a repair service for $30 plus return shipping. If you wan to do the repair yourself you will need to open the back of the monitor and look for the bulging capacitors. To see what the bad capacitors look like go to our site at: www.ccl-la.com Replace any bulging caps that you see and you should be back going. You will need to use high temp capacitors marked 105c. If you have any questions about the repair or repair service just let us know at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 07, 2009 | Envision G218A1 22 inch Monitors
Flashing green power light on monitorblack screen
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 09, 2009 | Envision H190L Monitor
Computers & Internet Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
