Question about Microsoft Windows XP Home Edition
My Dell Inspiron 510m laptop will not start up. One of the 3 lights next to the sart button turns on and flashes for several seconds then goes off. How can I fix this problem?
  • leslibell Jun 14, 2009
    Thank you both for the help, removing battery and unplugging did not work. The light still flashes and then stops. How could this happen so suddenly? It worked fine until this morning? Unfortunately I am in Haiti no dell support here that I know of, but thanks anyway!
  • 52 Answers
Those diagnostic LEDs indicate a No POST situation. Most likely, the motherboard, memory cards or hard drive is the root cause. Please contact Dell Tech support, they have the list of the meaning of diagnostic LEDs
Posted on Jun 14, 2009
  • Palani Natarajan
    Palani Natarajan Dec 18, 2010
    I have the same problem. Lesibell, did you get this fixed?
  • 453 Answers
Hello !!! Looks like your system is facing a No POST issue. Try these following steps 1) Try removing all the connected external devices like USB flash drive/ printer/ external hard drive / external mouse / docking stations webcam , etc. 2) Remove the battery and AC adapter power cord and press the power button. This will power drain your laptop. 3) After this step if you are still unable to resolve the issue. Then some internal component in the laptop is faulty. You may have to try reseating the memory, Hard drive , Optical drive, and PCI cards in the system. This may resolve the issue. But it is advisable to do it with the help of a DELL technician. Check you manual for the technical support number. Good luck !
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
How to reset the system clock on a dell 510m tried it in tne bios they light up but wont alter,, if the battery is low how and where is it locted i had to pick a diffrent laptop to send this post as my...
Peter, your system clock can be reset on your Windows screen, either in the lower right if you have the time function displayed (double-click to time and make any adjustments) or by going to Control Panel/Date and Time icon to do the same thing.
Nov 19, 2009 | Dell Inspiron 1525 Notebook
I am looking fro lan card driver and sound card
Here is the link that goes through support.dell.com and should take you directly to the Dell Inspiron 510m drivers and downloads page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_510M&os=WW1&osl=en&catid=&impid=
If for some reason this link does not work you can do the following:
1. Goto support.dell.com
2. Select drivers and downloads from the middle of the screen
3. From this point you can either select to enter your service tag number (should be on your pc) or you can do like I did and select Laptop, then Inspiron, then scroll down to 510m (you will actually have to scroll down to the 5000s because it is not listed from smallest to largest)
4. Once you have selected the 510m model it will bring you to the same page as I have linked above.
Finding your drivers -
I only saw one file listed under Audio so you could start there. Just expand the selection titled audio and it will give you options to download the file and install it just like any other installation.
Sound drivers usually require a reboot so anticipate this.
For the network driver I think I only saw one actual Lan card driver listed and it was towards the bottom under the selection titled Network.
It was the 10th one down and it is titled Intel Driver - (R) PRO/100 VE Network Connection.
Download and install that and hopefully that gets you going.
Good Luck,
Taco~
Apr 17, 2009 | Dell Computers & Internet
Dell 5160 orange light
I have never found hibernation to work successfully.
Disable hibernation if you ever get it started.
Try reading the manual on how to restart for hibernation, press "spacebar", "enter" or something.
Oct 10, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
686 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
