Question about GE Dryers
Dryer will stay on when started
When I turn my dryer on it automatically turns off after I let go of the "start" knob. It sounds as if the motor is not catching but I am not sure. 2 days ago our laundry sink overflowed onto the floor I'm not sure if that has anything to do with it. The water drained to our sump pump so nothing was immersed in water. Any suggestions for troubleshooting?
    Scholar:
    New Friend:
  • 111 Answers
Don't do GE products if you have a push to start then I would suspect the centrifugal switch in the motor this is what keeps a closed electrical loop for the motor
Posted on Mar 23, 2014
  • 67 Answers
SOURCE: My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Posted on Mar 21, 2007
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
  • 1462 Answers
SOURCE: GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Posted on Jun 26, 2008
buffalonyman
  • 1865 Answers
SOURCE: Broken Start Knob
You can buy this switch from ap wagner for $24.50
Go here and put in your model number, and the parts list will come up
http://www.apwagner.com/
Posted on May 21, 2009
  • 161 Answers
SOURCE: I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Posted on Mar 06, 2010
My GE dryer knob hums when I turn it on, but it will not stay started?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE Dryers
Will not stay on. if you hold knob it will go but will not stay on automatically
heatman101
Jul 28, 2011 | GE DBSR453EBWW Electric Dryer
I HAVE A GE DRYER DBXR453GA2WW. We replaced the belt. The start knob is missing but we can still get it turn on by manual turning the apparatus underneath the knob. However, the dryer will not stay on.
If the dryer starts but will not stay running, the cientrifugal switch in the motor is likely faulty. The motor will probably need to be replaced.
Kelly
Mar 24, 2011 | GE Dryers
When I push the "push to start" button (knob) on
heatman101
Mar 14, 2011 | Kenmore Dryers
Hi, our gas viking dryer overheated and does not want to stay on when start button is turned and released. when button is held ... motor sounds fine. (so it sounds) prior to the problem... dryer did...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Dryers
I turn the start knob and it just makes a buzzing sound
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
Dryer will not stay on
That sounds like the motor is bad.
Dec 28, 2009 | Kenmore 800 7982 Dryer
When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
May 05, 2009 | Dryers
Dryer problems
it sounds like the start windings in the motor may be faulty,is the motor covered in lint,try cleaning it but you may need a new motor.hope this helps.if you hold the start button does it stay running if so its the motor.you can use an amp meter to see what the amps are.should start at about 6-7 amps approx and then drop back to about 2-3. dont know what brand you have.
Mar 15, 2008 | Dryers
It won't start
Sounds like the motor start winding or motor relay is bad.. or something caught in you exhast blower. See if you can turn the drum with your hand.. if so you can try, helping it take off while having someone turn the start knob if it starts you know its the motor
Aug 19, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
37 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
