Question about Panasonic SCBT230 Theater System
DRAW WONT OPEN manually or remote!
And remote doesn't seem to work atall , batteries good!
05 gmc envoy keyless entry has new battery but still wont work, also have to jump the battery every morning. Any suggestions?
The remote can be checked. If it works, then the BCM needs scanned to what is wrong. Battery, first have it tested. If it is good, then the electrical system has to be tested for a draw. Most common draws are the alternator, starter, radio, and lights inside the vehicle.
Nov 10, 2016 | GMC Cars & Trucks
Vt comm remote wont open the doors but the key will open the drivers door manually and starts the engine?
have you checked the battery in the fob needs to be a good one as the cheapper batterys dont work
Feb 12, 2014 | Mercedes-Benz C-Class Cars & Trucks
Something is draining my battery on my 1998 Cadillac DeVille
I suspect parasitic draw. All vehicles draw some power from the batteries when the car is shut off. Certain accessories such as clocks, radios remote door openers and alarms always need power. The normal power used is called parasitic draw.
It is always a very low draw so it doesn't run the battery down. If you install accessories like shortwave radios or plug things like inverters and portable refrigerators into the accessory socket and operate them too long without the engine running you can drain your batteries to the point where the engine won't start. If there is an electrical short in the vehicle or a malfunctioning accessory it could be drawing much more than its normal load causing a drain on the batteries. If you leave your door open and the inside lights stay on all night you could drain the battery down till the car won't start.
Here's also a good resource for your car specifically on narrowing down the cause of the drain.
Oct 23, 2012 | 1998 Cadillac DeVille
Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Toshiba Televison & Video
Yaris hatchback wont open
The remote may have a bad battery or the system has lost programming, refer to the owner's manual to change the battery in the remote and if that doesn't cure it the dealer must use a special tool to reprogram the system to the remote frequency. This solution is based on the fact that both the remotes don't work, the remote can be bad, this is esp true if it has been dropped.
Jul 27, 2012 | 2008 Toyota Yaris
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
May 07, 2011 | Kicker ZX-350.4 Car Audio Amplifier
Battery draw
either that or your stator or the rectifier are not longer working right. try to check the output of those.
how old is the battery? if you have a battery tender, try putting the battery on the battery tender for a while.
if you have a draw on the battery, check any accessory that you may have installed and the cables that goes to them. look for loose connections or rusty ground
Apr 28, 2010 | 1984 Honda VT 500 C Shadow
My 2006 Pontiac Grand Prix won't start. The lights/battery is working. I can hear the fuel pump ingaging. I've checked the fuses & they seem to be fine. I'm use to looking at manuals that aren't so...
Either the battery is bad or the connections to the battery are corroded and/or loose. The lights may work but that doesn't mean the battery is good. The lights only draw about 20 amperes, the starter draws from 200 to 400 amperes.
If the battery connections are tight and clean, then most likely you need a new battery. A car battery store can test this for you.
Jun 18, 2009 | Pontiac Grand Prix Cars & Trucks
Razr V3
do u have ur sim card in? do u have service where u are? go to settings>network>new network see if itll work
Jun 14, 2007 | Motorola Mobility RAZR V3
Panasonic SCBT230 Theater System Logo
32 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
