Installed new hdd and win vista, g way 400sd4, wifi no work
SOURCE: Drivers for Gateway 4530GZ
ok what you do make sure its a genuine copy then load internet explorer nad go on to windwos update and iff yu dont have a internet connection of any sort on it then go tohttp://support.gateway.com/support/drivers/search.asp?st=pn¶m=4095 this should solve all your problems tht is all the driver s nown to man for that cmputer
SOURCE: gateway 450rog notebook cleaned hard drive and
I took a look out on Gateway's download site and found the usual drivers for your box.
gateway's download site
In particular here is the url to the network driver I think you are looking for
network driver
Hopefully you can use a friends pc to connect to this web site, download the driver onto a usb stick, and then take that to your laptop and install the driver.
good-luck.
SOURCE: I need gateway 7330gz video driver vista or Win 7
There are none...sorry, don't think ever will be, only XP is supported, you could try XP SP2 compatibility mode, it may work?
SOURCE: Just installed XP on the MT6456 Gateway laptop.
No such luck on drivers. Not all computers HAVE XP drivers. Look up the name of the audio driver in your owner's manual and see if you can find a manufacturer's website for the audio. Dell does not have it at this time.
SOURCE: need drivers for nx500s ethernet, wifi and network
All of your drivers should be available on the website at mpcdrivers.com. If you have yellow flagged items in control panel/device manager, you need to uninstall the non working driver before installing the right one, otherwise, windows will reload your old driver and cause conflicts with the new one you are trying to install
