Question about Sanyo SR-4910M Compact Refrigerator
Water under bottom lining
The bottom of the refrigerator feels like there is liquid under it. the bottom is pushing the crisper drawer up and it is hitting the glass shelf making it hard to open. The ref is working fine other than this. I don't see a drain down that low.
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water leaking
If there is water under your crisper drawers your drain line under your freezer panel is clogged up or frozen over.
Jul 28, 2012 | Amana ARB2257CSL Bottom Freezer...
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Sanyo SR-4910M Compact Refrigerator Logo
24 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
