Question about Music
Peavey xr1200 blows 8A fuse after about one second. Old mixer, seldom moved, has worked fine for years
Power switch was by-passed in a pinch years ago, but unit has worked fine since. Just began blowing fuse when plugged in.
    Sergeant:
  • 336 Answers
If it blows a fuse when powered on, it has a dead short somewhere. Old units do this when the capacitors (filters) get old and dry out. These create dead short circuits. I recommend going through the unit and change out the bad ones. They can usually be spotted easily. They look like little cans glued on the board with an "X" on top. They are usually blue, gray, or black. The X on top is a weak spot allowing the top to open or pop up when they go bad.
Posted on Mar 29, 2014
On my peavey xr1220, when I turn on the power switch the board does not power up. What could be the problem?
Probably a fuse ? I have been servicing a lot of Peavey equipment lately and they have some poor circuit designs, a lot of internal un accessible fuses, I might be able to get more info ?
Feb 22, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Peavey amp
Most likely a power supply problem. Take it to the repair shop.
Apr 06, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
No power
switched mode power supply and class d amps, take to shop that can work on these, it should of had a 5 year warranty.
Mar 30, 2014 | Peavey XR 1212 Powered Mixer Mixer Powered
Xr 1200
Old age has finally caught up with both myself and your vintage Peavey. Things like shorted diodes and transistors sometimes do not physically give themselves away, Also, many times it takes a trained eye to discern the components that have failed in a more discrete manner. It's either repair shop or replacement time which I recommend the latter.
Mar 22, 2014 | Peavey Music
Peavey xr600f
250V 8A SL(Slow-Blow)
Sep 29, 2013 | Music
One side of my peavey xr86000 power mixer blew a fusework
Any unit that blows fuses needs to be serviced. Do not keep putting in fuses only for them to be blown again. Each time you put in a fuse and it blows, it will create more damage to the amplifier.
Jan 14, 2013 | Peavey XR 8600D Class D Powered Mixer
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey XR8600D main outs simply stopped working. Unit is less than a year old but I am too far from any repair shop to make any use of the warranties (Samoa, South Pacific). I turned it on one night and...
These had a little switch on the far right side that shifted modes from stereo to main and monitor. Check the position as it is tiny push button. Also try sending line levels DIRECTELY into the power amp inpout jacks to verify the amps are both OK... if not, the repair shop is only option... there is only one main fuse for the amp and if one side is working, then the fuse is good.
Oct 29, 2011 | Peavey XR 8600D Class D Powered Mixer
Music Logo
75 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
