Question about Whirlpool Washing Machines
Llavadora whirpoll s-18-wiw 250 syq
No centrifuga y no bota el agua me presenta codigo de error
5 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: quisiera saber si hay que cambiar tarjeta
Checkas aqui... http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WTW6600&siteCd=WHRCOM porque hay informacion en espanol en los instruciones por tu lavadora.. los instruciones dice: Oprima Pausa/Anulación (PAUSE CANCEL) una vez para despejar el código. Presione Inicio (START). Si el código aparece nuevamente, llame al servicio técnico.
Posted on Jun 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: no realiza el sclo de lavado
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: CADA VEZ QUE EMPIEZA
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%%
Posted on Sep 21, 2010
jsrock516
  • 5911 Answers
SOURCE: que significa el codigo de
Todos los códigos de error que aparecen en una hoja de datos en la lavadora. Para acceder, levante el panel superior de la máquina y buscar entre la bañera y el panel frontal. El panel superior es levantado por la inserción de un cuchillo de la masilla a lo largo de la costura en la parte frontal superior se reúne la parte delantera de la máquina, cerca de dos pulgadas a cada lado. Empuje el cuchillo de la masilla en la costura para liberar los clips de sujeción y levante la parte superior.
NOTA: Asegúrese de que usted se aferra a la parte superior, por lo que no se abre y se rompa. Se recomienda que utilice un poco de cinta para mantener la tapa cerrada.
La hoja incluye todas las definiciones de los códigos de error, solución de problemas, diagramas de cableado y los procedimientos de diagnóstico.
Si usted todavía tiene preguntas, por favor, después de vuelta y me dejó saber. Espero que esto ayude.
Posted on May 19, 2011
Cafetera Krups XP7230 bota agua por debajo
The problem lies with one of the hoses taking water to and from the heating element - hoses either have a crack in it or one of the two connections is no longer water tight.
Feb 12, 2016 | Cars & Trucks
Como reparar c?digo P1346 en un terios
Como reparar el codigo de error p1346 en una terios '2005 ...
www.faqqq.com/.../como-reparar-el-codigo-de-error-...
Translate this page Question Product: 2005 Daihatsu Terios 1.3 Question Details: Como reparar el codigode error p1346 en una terios View Answers Search Related.
cual es la pieza P1346 de la toyota avanza,ya que enciende
www.justanswer.es > Coche
Translate this page El c?digo P1346 de toyota refiere al sensor de distribuci?n variable del ?rbol de levas o el circuito sensor de posici?n fuera de rango, esto se condice con el ...
P1346 OBDII Escaner Codigo Diagnosticos OBD2
www.copartes.com > Foros > Errores Codigos OBD-II
Translate this page ... Codigo Diagnosticos OBD2. Introduzca el Codigo OBDII a Consultar o bien ABS, Check, Motor, Aceite, etc. ... P1346 OBDII Escaner Codigo Diagnosticos OBD2. Informaci?n ... Como reparar los rotores delanteros de un Kia Optima 2001.
p1346 obdii escaner codigo diagnosticos obd2
Feb 08, 2016 | Cars & Trucks
Que significa SRS en el panel de mi mitsubishi mirage 1995
Hola:
EL codigo SRS se refiere al sistema de seguridad del vehiculo (Air Bag System), y aparece cuando se presenta algun codigo de falla en el mismo.
La presencia de un codigo de este tipo no sera eliminada con solo desconectar la bateria durante algunos minutos; necesariamente tendra que llevar el vehiculo a su representante o algun taller que cuente con lector de codigos (scanner) para determinar exactamente que codigo de falla se ha presentado, Solamente con este codigo podriamos ofrecerle mayores detalles.
Suerte.
Jul 10, 2012 | 1995 Mitsubishi Mirage
Tengo el codigo P0420. que es lo que tengo que hacer en este caso, es mucho problema ese codigo.
Lo más fácil que hacer primero es un control visual de las cosas. Inspeccione visualmente el sistema de escape que no haya fugas, comprobar el convertidor catalítico de abolladuras, huecos, decoloración severa, y compruebe que un cascabel en su interior. Si alguno de los syptoms están ahí, el convertidor de posibles necesidades de reemplazo. A continuación, inspeccione visualmente el sensor de O2 aguas abajo (detrás del convertidor). Compruebe si hay cables rotos, errores evidentes, etc Si todo lo que los cheques, usted querrá comprobar el funcionamiento del sensor de O2. Para ello, tendrás acceso a una herramienta de exploración o osciloscopio. Compruebe que la forma de onda es bastante estable. Si la lectura varía entonces el sensor es probable mal y tendrá que ser reemplazado
Jan 03, 2011 | 1999 Mercury Cougar
La maquina cuando esta lavando sale f21 y no escurre el agua
F21 DRENAJE DE LARGO
Si el tiempo de drenaje supera los 8 minutos, el apagar las v?lvulas de agua.
NOTAS: Despu?s de 4 minutos, el "SD" error se mostrar?, a continuaci?n,
4 minutos m?s tarde el "F/21" c?digo de error se mostrar?. Pulse
PAUSA / CANCELAR dos veces para borrar la pantalla.
Posibles causas / Procedimiento
1. Revise el tubo de descarga y aseg?rese de que no est? conectado o
doblada.
2. Desenchufe la lavadora o desconecte la energ?a.
3. Compruebe las conexiones el?ctricas en la bomba y aseg?rese de
la bomba est? funcionando.
4. Compruebe la bomba de drenaje de objetos extra?os.
5. Enchufe la lavadora o reconecte el suministro de energ?a.
Dec 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tengo una lavadora electrolux maxi clean y me manda codigo de error e4 que tengo que hacer
Buenos dias tengo una lavadora maxi clean que no centrifuga y los demas ciclos los hace sin problemas, como le reviso l control de nivel por que la bonba suena como si tubiera agua la tina por mucho rato.
Gracias
Nov 03, 2010 | Washing Machines
What is an F1 error message?
El codigo F1 para las Whirlpool Cabrio lo define la se?al de presion fuera de rango, para esto, primero hay que verificar el estado del tubing plastico ? manguerita que va de la tina hasta el sensor que esta en la tarjeta principal, que no este rota y/o doblada, luego realizar el test # 6, nivel de agua y calibraci?n del sensor de presion. Para esto hay que estar seguro de que la tina este sin agua, al igual que el tubing, luego entrar en test modo 2 y seguir los pasos.
Jul 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Tengo un codigo de falla P0301 se que es una falla de ensendido pero no logro ubicar si es una bobina o un inyector
Verifica el retiro de los inyectores, podria tratarse de la obstruccion de alguno de ellos, con residuos de agua y sedimentos en la gasolina. Hacer limpieza de los mismos, verificacion de o´rings, y un escaneo final para el borrado codigos.
No estaria demas, usar bujias mopar con una grado termico mayor.
Suerte (recuerda valorar esta ayuda).
Nov 09, 2009 | 2002 Jeep Liberty
Washing Machines Logo
289 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
