Question about Kenmore Sewing Machines
My Kenmore sewing machine model 158.13571 is binding up so it is hard to turn the rotator and the motor is not strong enought to move the mechanics... Any one have an idea why that might happen?
Model 158.13571 binding
Hi, the same sort of thing happened to me last week and I lubricated the moving parts with machine oil. Since then, it all seems to be fine.
Posted on Apr 07, 2014
I have a sears kenmore sewing machine model 148-13100 where is oil needed?
If it is an older mechanical machine, 1-2 drops oil (ONLY fresh, good quality sewing machine oil) applied every place where metal rubs against metal. AVOID belts, plastic gears, CAMS. Slowly hand-rotate or wiggle the handwheel, watch where metal parts move against each other and apply a couple drops. Be sure to get the top mechanism, the side mechanism where the needlebar is located, and under the sewing surface, ie the feed dogs area. Also, move levers and dials and apply a couple drops where metal rubs metal.
Jan 05, 2017 | Kenmore Sewing Machines
Where can I download a free service and/or parts manual for my unidentified machine?
Service manuals are sometimes difficult to find as the manufacturer intended only technicians would have access to them. Sears, however, carries manuals and parts diagrams for many Kenmore machines. However, they may not be free.
Sounds like your machine has suffered from some neglect over time and has seized from lack of oil (possibly the wrong type of oil). Even though you have oiled it, the old oil has most likely dried out in place preventing the parts from moving freely. Pick up a bottle of liquid Tri-Flow Synthetic Oil from the local hardware or bike shop. While slowly hand-rotating the handwheel, apply a couple drops of oil every place that metal rubs on metal (including the selector dials & levers, feed dog mechanism, etc.). Do not oil plastic parts, cams, or belts.
Then, direct hot air from a handheld hairdryer into the internal mechanics of the machine (be careful because the metal will get hot and can burn your fingers). It may taken multiple applications of alternating oil and hairdryer. This method has worked well for many frozen older machines. Just requires patience and elbow grease (or rather Tri-flow :^O ).
Apr 07, 2016 | Kenmore Sewing Machines
What could be causing my Kenmore Sewing Machine to feel like its binding up to the point it won't move at all ?
most of these problems can be traced to cotton and fluff jamming the shafts around the bobbin area
you could try removing any jammed threads and fluff or take it to a sewing machine service center ( any one if not under warranty) as all know what to look for when a machine has your problem
remember quotes before work done
Mar 24, 2016 | Kenmore Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Brother sewing machine
There is cluch on the handwheel that connect motion,try to tighen this If negative,There are two small bevel gear (hard PVC )connecting to the upper crankshaft where the handwheel was connected.This transmit motion when motor run, most commonly the vertical rod where one bevel gear was connected maybe broken or viceversa at the upper crankshafting that holding the bevel drive gear is broken try to check this.
Mar 06, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Jan 20, 2009 | Sewing Machines
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
JUKI MO-634D trouble
Well, you might just need a good oiling. Make sure the machine is not threaded and there are no thread snarls where the loopers interact. It also pays to insert new needles and observe the loopers and needles interact. they should come withn .01-.5mm of touching eachother; there should be no hard positive contact between loopers and needles. So, if its tight to turn over by had, this is usually a cam or bushing that need oiling, or thread that got sucked into the machine and is binding the thing up. What I would do is remove the covers, slip the motor belt off, turn over by hand. If it frees up, the bind is in the motor, if its still tight, then id look for thread, and oil the machine with a light weight oil (sew mach oil, tri-flow... NOT 3in1 oil!). If you have a keen eye, you can wiggle the handwheel and try to observe what parts are moving slightly, and which are not. using that method you may be able to track the bind to a section of the machine or even a specific shaft/cam/component of the machine. Another common bind point in sergers is where the knives mate. Move the top knife to its idle (non cuttin) position and see if this relieves the bind.
Jun 27, 2008 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
71 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
