No sound from Phillips TV
No sound from internal speakers
    Habit-Forming:
  • 84 Answers
Make sure you don't have the mute turned on.
Also, check in the setup menu to make sure the speakers are turned on.
Posted on Mar 23, 2014
Sound will not come on the televison
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers. This setting will prevent any sound from coming out of the internal speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use internal speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
MY PHILLIPS 32 INCH TV HAS NO SOUND.
the problem may be in the main video/av card get on ebay to see if you can find one
Dec 18, 2014 | Televison & Video
MY 32 INCH PHILLIPS TV HAS NO SOUND.
Try checking captioning options or dish aim to satellite.
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
Bypass hdmi to get sound to PC speakers
does your tv not have an audio out, if so, you could turn the tv's internal speakers off and just use the audio out jacks instead.
Feb 26, 2009 | Westinghouse 25.5" Widescreen Flat Panel...
No audio out connecter on back of Phillips 52 in TV
Hi and welcome to FixYa,
Almost all (European) Philips have a SCART type connector as shown below.
With the use of a SCART Adapter (below), the outputs are available as Audio L/R & Composite Video and S-Video either as output or input.
Good luck and thank you for using FixYa.
Feb 09, 2009 | Bose Cinemate Digital Home Theater System...
No volume
On the back of your set there are 2 switches that tell the tv whether you are using the internal speakers or the external speakers.
Make sure the switches are set to internal so the speakers in the TV receive the sound signals. If they're set to internal maybe the internal speakers are bad. Set the switches to external and hook up external speakers to the speaker terminals on the back of the TV. If neither setup works then it sounds like an output transistor or related parts.
Sep 01, 2008 | Proscan PS60690 60" Rear Projection...
No sound...no... it is not the mute button
Did the TV produce sound along with the surround system in the past?
Verify the audio is connected through the TV and not directly to the surround system.
Usually there is an option in the TV setup to disable the internal speakers if the TV has variable audio output or audio pass-through. In Sony TV's this is usually one of the later menus and the option turns the TV speakers on or off, but it depends on the make/model of TV.
Apr 06, 2008 | Philips 32PF5320A 32 in. LCD Television
Picture on TV great. NO sound though
shannonlamb- check the back of your set where the cable ect. hook up, there may be a button on the back for speaker on/off.If not then check the menu to see if there is speaker on/off in menu make sure it is on.The last is the old tap test, just tap the back and sides,if you get sound at all it is internal cold solder joints.Let me know ----- cooltek Feb.15/08
Dec 31, 2007 | Sony KV-36XBR250 TV
TV has no sound
Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
Nov 18, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
