Question about Maytag LSG7806A Front Load Stacked Washer / Dryer
How do i remove the knobs from the front of my maytag washer
  • Maytag Master
  • 3,361 Answers
Http://www.servicematters.com/maytag_library/docs/16000416.pdf This should help.
Posted on Jun 14, 2009
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
Maytag neptune mah8700aww has an error tE, lower case t and upper case E.
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Drain wont drain on a epic washer where is the drain filter located at
The drain filter is located in the pump behind front bottom panel. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly.
Nov 14, 2010 | Maytag EPIC MFW9700S Front Load Washer
I have a maytag stackable washer/dryer and I need to change the water temperature switch. Does anyone know how to go about doing this? I already have the part.
you will need to remove the front panel screws which will allow you to remove the end caps off the front panel after removing the control knobs,then you can replace the temp switch by removing the screws off the controls main body
Mar 07, 2010 | Maytag LSE7806A Top Load Stacked...
Maytag A408 washer- needthetimer part off for new
look at the link: http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153000&brandID=...
pop the front chrome cover off the knob, slide the spring clip off the timer shaft, remove the spring and bezel, then remove the dial indicator. Reverse this process to reinstall the knob.
Nov 18, 2009 | Maytag Performa PAV2200
Maytag Neptune front loader won't rinse/spin
you have something clogging your pump
remove the back panel
clamp the tub to pump hose or deal with all the water when you remove the pump - three bolts
open the pump - three screws
remove the object blocking the impeller
check tub to pump hose and pump to drain hose thoroughly
reassemble
be careful of the machine opening once you remove the rear panel it is razor sharp !
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
No screws in the front of my maytag topload washer. do I acess the timer from the rear
Yes you do remove the rear plate by removing the back screws remove the knob off the timer if there is a nut holding it to the frame loosen it but do not remove until you take the back cover off when replacing the timer remove one wire at a time to keep them in order. Please rate if helpful.
Aug 07, 2009 | Maytag Washing Machines
How do you get the timer off a maytag atlantis toploader?
first unplug unit,,remove the three top screws across backof console..now on timer knob remove the outer most cap or the center cap..remove the clip,,carefulf now theres a spring behind knob dont let it fly ,,remove dail...good,,,noew go back to console and flip it down top towaeds you bottom away,,jiggle just a touch now your in,,remove 2 timer screws from front ,,reverse to to put together...onthejob
Dec 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Main Control Knob Removal
Pull the knob off, some units have a set screw that holds it inplace but most are just tight fit. May need to pry it off. The screw that holds the control in the front plate is under the knob. Take the back plate off which is just behind the control. label the wires as you remove them or unplug one wire and put it on the same plug on the new control.
Feb 03, 2008 | Maytag PAV2300 Top Load Washer
Maytag LSG7806A Front Load Stacked Washer / Dryer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
