Question about Photography
Replace leg I pulled out the middle leg section of my Benro c358 mb tripod and can not get it back into the upper section. At the upper end of the middle leg section, a small plastic strap about 3/4 inches wide is /was wrapped around the leg section and it has come off. I need to know if this plastic needs to be glued to the leg section or not. Maybe if I forced it a lot I might get the section back in (doubtful), but before trying that I need to know what to do with the plastic strap. Any help is certainly appreciated. Thanks Billy
  • 2 more comments
  • Billy Horne
    Billy Horne Mar 23, 2014
    I have the tripod leg fixed now. A Youtube video I found showed how the little plastic strap was wrapped around the leg. This enabled me to put the strap on properly and insert the center leg into the upper leg. The tripod now works.
  • Billy Horne
  • Billy Horne
    I accidently closed the above (previous) post before I could thank the everyone.
  • Billy Horne
jessee007
  • 310 Answers
SOURCE: plastic tabs on leg locks broke
yes with the original plastic locks. "junk" go to ace and you will find some differant lock slides. I did and they are not plastic!
Posted on Dec 31, 2007
devocap
  • 201 Answers
SOURCE: ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Posted on Feb 04, 2008
SOURCE: parts for a velbon tripod
hi there, i think you can obtain the parts directly from Hakuba USA. www.hakubausa.com they're the USA distributers for Velbon and will actually repair it... if you can't by simply replacing a part. also a phone # 1-800-423-1623 and a seperate # 800-886-2236 to order quick release plates.
Posted on Jan 05, 2009
  • 175 Answers
SOURCE: Broken Leg Clamp - Manfroto 055SB Tripod
For parts, try www.bogentripodparts.com
Posted on Nov 12, 2010
  • 685 Answers
SOURCE: Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
bogen and manfrotto are the same company
Posted on Dec 12, 2012
Benro A2682T Travel Angel 2 Aluminium Tripod instruction manual
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Alternatively the manufacturer's support website may be able to help you.
Not really sure why you need a manual, anyway - most tripods are similar : legs set to correct height, pointing downwards, splayed for rigidity, then camera goes on top, using the head to point it in the correct direction.
Jun 27, 2016 | Benro Photography
Where is serial no. on mefoto tripod
Try to call them to know where is exactly located.
We can help! Just contact us directly at info@MeFOTO.com or 914-347-3300.
May 10, 2014 | Benro Photography
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
Customer service for giottos
To order service parts contact the importer:
Canada-JCL Sales (Richmond B.C.)
USA-HP Marketing (Pine Brook NJ)
-Inform them of the tripod model and possibly provide them with photos of where the spreader arms attach to both the legs & the center column...., you may require additional parts.
Mar 31, 2013 | Giottos Vt-809 3-section Compact Tripod...
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
Feb 04, 2008 | Manfrotto 055NAT3 Tripod
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Photography Logo
420 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
