Question about Garden
Jondeerehow to lift cab
Leaking hydraulic line
    Champion:
  • 279 Answers
Get a new line made at O'Riellys auto parts or NAPA
Posted on Jun 03, 2014
Hydraulic arms will only lift halfway up using control levers in cab
Low fluid , or Hydraulic Pump not working 100% or dirt in system.
Mar 16, 2015 | Garden
John deere 3800 tranmission oil leeking under cab somewhere
Hi Joe:
Nice looking tractor. I'm guessing you may have a leak in one of the hydraulic lines. There's usually access panels that you can remove so that you can see the lines and fittings. Sometimes a mirror on a handle and a flashlight will help you locate the problem. Once you find it, replacing the hose is usually easy and your local hydraulic shop will fabricate the needed part at a reasonable price.
SAFETY FIRST! Make sure that all hydraulics are lowered fully and that there is no residual pressure in the hydraulic tank. Open the filler cap to make sure.
Hope this helps.
Mar 05, 2015 | John Deere Garden
Need to lft cab on6420 j.d.tractor leaking line
You should have a jack to jack the cab up.
Mar 22, 2014 | Garden
03 F150 spongey brakes after replaceing brake cylender and bleeding brakes?
This sounds like a bad brake line, these trucks are famous for rotted lines behind gas tank, make sure there are no leaks, this sounds like a leak or a defective master cylinder, if this is the same problem then i would say it is a line also check the rear brakes for leaking wheel cylinders unless you have rear disc brakes, check calipers for leaks.
Take a good look at brake system for leaks, hold brake pedal a few times and let is sink to floor , do it about ten times and then look for a leak, good day
Jun 24, 2012 | 2003 Ford F150 Regular Cab
Tried to lift the roof on convertable XK8 and hydraulic oil started to leak from the ceiling arounf the light cluster. How do I get at it to fix the leak/problem
you have a hydraulic leak there are two lines that meet in the middle by the light cluster both lines should be changed you have to pull back headliner to see lines and leak one line runs under drivers side panel near side of seat and other line runs under passenger side panel near the side of the seat going to the back seats and to the trunk where hydraulic motor and fluid box is its a hard job and takes about six hours to do lines arer 214.00 fluid is 70.00 and about 800 in labor
Jul 05, 2011 | 1999 Jaguar XK8
The hydraulic pump does not shut off and the lift arms will not go down on my d19 allis chalmers tractor.
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Nov 18, 2010 | Dmm Allis Chalmers Tractor D19,d21,210,220...
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Hydraulics get were they won't lift anything like round hay bales etc.
can be a lot of different problems-check fluid level if low fill to proper level --leak in hydro line-check all lines for leak--air in system -bleed system -wrong hydro fluid in system-check for correct fluid---seal at pump leaking-check around pump--controls leaking not holding allowing back pressure--test controls for internal leaks repair or replace if necessary--hydro pump internal malfunction/valves/piston/gears-pressure test repair or replace if necessary
Feb 01, 2010 | Diesel Allis Chalmers 190xt Tractor...
1999 Dodge Ram 2500 changing front-to-rear hydraulic brake line
It will be a lot easier to do with the bed removed. It will also save time. So unfortunately yes that is true.
Jan 29, 2010 | 1999 Dodge Ram
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
