Question about Emerson/ruud 47-102077-02 Control Board X-13 151396
The fan or heater strop will not turn on
Theirs a humming sound that comes from the board
Humidifier not working
humidifier should come on after the fan comes on to supply warm air to the house. check the voltage coming off the circuit board. check between hum connection and the C (common) connection
Mar 16, 2014 | Goodman GMS90703BXA Heater
What does stropping mean?
Straight razors require daily stropping in order to straighten and re-align their edge. Stropping involves passing the blade in a back-and-forth motion over a strop, which is usually made of leather.
Feb 06, 2013 | Health & Beauty
There is a high pitched sound coming from my heater, even when the thermostat is turned off. The sound is similar to when you are close to an electrical tower. Please advise
If you have a fan blower on your heater, it may be that the motor shaft is stuck and you're hearing the motor humming. Which, if it is, will burn out the motor.
Here's a link to the Williams website. There you can download the Owners Manual for your Model Number heater. There is a good Trouble Shooting Guide in it, which may also provide more info on what's causing the humming noise.
http://www.wfc-fc.com/
Hope this helps you solve the problem.
Feb 18, 2011 | Williams (5009622) Ceramic Gas Wall...
I turn my thermostat to the HEAT position, I hear the Thermostat click and the Furnace begins to hum but no air comes out of the vents. Also if i turn the fan to the ON position air will come out of the...
need to go to furnace and watch it...if your hearing a hum the enducer draft motor may have failed...it should start first if there is no fault codes...reset unit by unplugging furnace or in some cases turning power switch off...turn thermostat on heat and watch unit ..the small enducer draft motor should start first the a ignitor glows and the should light...goodman units have a control board with a light on control board when it fails should flash a code and on the door or inside on lable should give you what that code is...hope this helps good luck
Jan 07, 2011 | Goodman GMS90703BXA Heater
Why does my electric fireplace makes a humming noise when on?
sounds like you may have a ceased fan get someone to look for you, but an electrical hum that is louder than normal usually means that the fan or a moving part is trying to turn ot move but can't so make's like a hum noise so seek a service agent
Dec 15, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
My microwave kenmore 66222500 makes a humming sound like if it was on when the door is closed. i have to unplugged it or leave door open to stop the humming sound. I tested the magnetron, the primary and...
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
Jul 28, 2017 | Kenmore 68361 Microwave Oven
My pool heaters starts to hum and the service light comes on
millivolt heaters generate their own power from the flame on the pilot max is usualy 750 millivolt, check all connections clean and secure.
Mmake sure the pilot is lit
Dec 31, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
AC fan won't run . No air coming out at all. Also heater won't run.
First check the fuse for the fan. If it makes a humming sound, check if the fan blades have jammed somewhere and being physically stopped, it creates a humming sound.Also check the insulation of fan armature to see if an of the coils have shorted out. Also dont forget to check the condenser/capacitor which initiates the rotation of the fan................sodeep
Sep 04, 2009 | 2000 Dodge Caravan
Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Nov 21, 2008 | Goodman GMS90703BXA Heater
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Emerson/ruud 47-102077-02 Control Board X-13 151396 Logo
Top Emerson Heating & Cooling Experts
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
