Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Electric kenmore range, it has a red circle around the fan and a red line at the bottom(conv) normal bake it switches between bottom red line and top, it only heats up to 200
It does not heat past 200 and a red circle around the fan and a red line at the bottom, for conv, for bake it switches between bottom and top red line
cactus bob
  • 267 Answers
SOURCE: I have a Kenmore Elite Electric Range and when I
this is a super common problem for all convection ovens . your motor is going bad . you can replace it yourself as long as your handy . parts can come from searsparts .com or any appliance parts store . any repair person you call to do the job should have no problem . these motors go bad every 10 years or so , or more if you use it a lot ..........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 17, 2009
SOURCE: Have a kenmore electric range that does not heat
I cannot no heat from the bake,convection,broil features.No codes show up and the computer seems to do its work.
Posted on Sep 27, 2009
  • 234 Answers
SOURCE: The bottom bake element does not heat up. I
Did you test the old element before you replaced it? If you did, then you would know that there is some other problem such as a bad wire connection or the bake setting control . Now you need to test each aspect of the wiring and controls that feed this element. macgivor
Posted on Dec 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Electric Range - Surface heats up fine,
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
  • 9 Answers
SOURCE: Kenmore Electric Range Model #911 9237313-All burners quit at once?
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Posted on Jan 22, 2012
Testimonial: "This did not fix the problem but easily could have been the reason my burners wouldn't work. I appreciate the suggestion."
Kenmore elite electric just delivered
It does that to speed up the pre-heating process.
Feb 09, 2016 | Kenmore Kitchen Ranges
Blodgett conv oven heating
a couple of things to check--are you baking more product than usual at one time?does your oven have a load control dial?if so the dial could be set wrong or inoperative.if your baking to much product than normally the excess moisture could cause this.has any electrical work been done to the oven or its power line.is the fan running clockwise?when you look at the fan do you see a tube in front of it?if so check for a blockage (tinfoil).lastly you could have a bad heating element.
Oct 03, 2007 | Ovens
Why are my rolls not cooking on the bottom but fine on the top and my element is working fine
My guess is this is an electric range. If I am right then it has 2 elements--one on top and one on the bottom. Plus you stated it has convection cooking. Sounds like the bottom element in not working right so all you are cooking with is the top element. In convection cooking the fan circulates the air for even cooking.and sometimes has its own element around the fan. Look closely at the bottom element for any burned out or melted areas that might show. Sometimes they just burn out with no outward signs.
Feb 22, 2015 | Kitchen Ranges
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
The bottom element in my Kenmore oven just got red
Yes. Unplug the range, remove the screws, holding the element, remove element, disconnect wires on the ends of the element. Installation is the same in reverse. Complete model number is needed for the part# of the element
Mar 04, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
