Question about Kitchen Ranges
My stove panel went blank.
Model # tef351ewb - my stove panel went blank I presses the clock button it came on so I reset the clock a few minutes later it went blank again. A few days ago I came home and the clock was blinking like we lost electricity, I reset the clock and did not think a bout it until Today. Is my stove dead?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Posted on May 01, 2014
3 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: I have a whirlpool built
it's the control panel behind that touchpad item. and it's not too difficult, just time consuming. My recommend is to grab a service manual online(usually around 20.00) which will provide good step by step,and also parts list.
spares? well, that's a good question. Until you have that part number, and the best way is to eyeball the one that's in side your unit(no offense to the printers, but mistakes can happen with manuals).
then you'll find out what it's like to be truly handy, eh?
Posted on May 31, 2008
micromaster
  • 3614 Answers
SOURCE: GE Stove tope range not working
did the timer was still functioning, and the only problem was it was not getting any heat, right>
Posted on Sep 04, 2008
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
I have a whirlpool built in oven. Model RBD275PDQ8. The display (control panel) went blank 2 months ago. I reset the breaker, nothing. Pushed buttons, it just beeps. 3 days later I pushed the upper oven...
May 31, 2008 | Whirlpool Kitchen Ranges
Can not re set time
Are you trying to reset the timer or the Clock? It's a bit different on each stove, but usually if it's the clock, you press the Clock button TWICE, the time will then begin to flash on and off. then press the + or - sign to increase or decrease the time. When you have gotten to the time you desire, PRESS the Clock button ONCE more. The time will be set, & then you should be all set :).
If it's the KITCHEN TIMER, Press the Kitchen Timer button ONCE, the timer will start flashing. It will usually flash all 0000's. Press the + sign to add minutes, then Press the Timer Button ONCE again, it will be set to the amount of time you added and will beep once the time runs out.
Disclaimer: This instruction is primarily for the General Electric Stove. If you state your specific model, I could be more specific.
Nov 12, 2010 | Ovens
Maytag Stove Error Message 5 A6
ok Alvin. help has arived .. turn off the power for a few min ( at the breaker box) turn back on see if clock will set . if not you may have a damaged membrain . now 5 A6 MAY BE A FAULT CODE.. in the control panel is a tec sheet with the codes . hope this will help .. mm
Dec 04, 2009 | Maytag Performa PAV2200
How do you set the clock on a stoves 059040411 oven?
I don't know what model oven this relates to, STOVES may be able to help you if you need to take this further. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Nov 01, 2009 | Stoves 720EF Electric Double Oven
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
Aug 02, 2009 | Stoves 720EF Electric Double Oven
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
161 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
