Question about Cub Cadet 50 in. 23 HP Kawasaki Twin Courage Dual EZT Zero-Turn Riding Mower
Kabota GR2100 oil plug will losen but not come out to change oil
  • Cub Cadet Master
  • 2,478 Answers
Is it plug or valve? Remove valve.
Posted on Mar 25, 2014
I have a zd21 kabota mower. what kind of oil ges in the tube behind the right side fender? its says oil but doesnt specify weather its hydraulic or motor oil
engine oil goes in the engine which will be at the dipstick hole or filler cap on the engine
anywhere else on the mower will be hydraulic oil
Apr 28, 2016 | Garden
Kabota 2200bx will start but will not keep running in the run position
change spark plug if that don't work. drain all gas out. inspect the fuel hoses, fuel tank, take carburetor bowl off if you see any dirt debris or water you may need to clean or rebuild the carburetor.
Sep 10, 2013 | Kubota Garden
18 hp kabota diesel is blowing black smoke at start up
Does the Kabota have glow plugs? Or just compression start?
If glow plugs, let plugs warm a little longer before starting.
Jan 09, 2013 | Cars & Trucks
I am changing oil on a 2004 buick rendevous and want to be sure I am working on the right drain plug. What I thougt was the plug is at the rear of the pan, but it doesn't want to loosen.
the oil plug should be a 5/8" plug at the lowest pount of the oil pan and is usually torqued on prettey bood if it was last changed at the dealer or a garage, you may need to use a breaker- bar to losen it, of there is no room under for a bar then briskly tap the end of the wrench with a hammer or the hard part of your hand, PLEASE DO NOT INJUR YOURSELF
Jun 29, 2011 | Buick Rendezvous Cars & Trucks
I have a 1990 4-runner auto. I need to drain some oil out. i put too much in. Where is the thing i need to drain the oil out of and what tool do i need to use? how much oil should it have in...
the drain plug should be on bottem of motor.you need some kind of pan to catch the oil in. i wouldnt take the plug all the way out just losen enough to let some drain out. probley going to be a 15cm wrench or sockit and ratchit.to losen bolt
Sep 13, 2010 | Toyota 4Runner Cars & Trucks
Want to change the oil on my 2000 saturn sl, and want to make sure i have found the oil plug, where is it located and what does it look like? the manual shows a picture of the oil filter and it is just...
it sounds like you are looking at the right part. I do all the oil changes for my families vehicles and everytime i do it never looks like i have either. The reason is that all the dirt and debris from the road clings to the warm oil pan/plug making it look like its been 10 yrs since its been unscrewed. But like i said you are looking at the right place.
Nov 21, 2009 | 2000 Saturn SL
How do you change the engine oil
losen the drain plug with a oil pan close by then let drain into pan until no more oil comes out tighten plug back to bottom of the motor. find oil filter and losen the filter with drain pan underneath let drain and replace with new oil filter then wipe everything clean and then start filling motor with new oil ...... easy maintanence
May 17, 2009 | 2007 BMW 335i Coupe
Which pulley is the serpentine belt adjuster on 2002 xg? and how do u change it?
To replace the sepentine belt: Get a 9/16 socket with a extension. Look under the car and look for the oil filter. Next to the oil filter you will see a bolt. Use the sock and losen the bolt. This will losen the tensioner. You will notice the bolt coming out, push the bolt up and the tensioner will allow you to remove the belt.
Jul 29, 2008 | Hyundai XG350 Cars & Trucks
Cub Cadet 50 in. 23 HP Kawasaki Twin Courage Dual EZT Zero-Turn Riding Mower Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
