Question about ECHO, Inc. PB-251C Handheld Blower
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed fuel, still wont accelerate loike it use to. What else can be done I have checked all fuel lines too. I have changed fuel, cleaned out carb. still have a problem
Guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Posted on Jun 14, 2012
Why does this happen to several gas blowers? I have 3 blowers hand held and back packed that after awhile they will not accelerate to high speed.
thanks frank
Posted on Jun 15, 2009
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
I have a echo pb251 gas blower,stop running,has spark,rebuildt carb.fuel filter,after no start,plug is wet & sparks but wont hit/start
screw air mix screws in the out like a half turn each, one controls the high end speed and one controls the idle, do idle first and adjust just a little rich then do high speed screw.
Nov 03, 2014 | Echo Garden
What happens if you use 40:1 fuel to oil mix in a 50:1 echo pb251 leaf blower engine?
it is always better to use to much oil than not enough, using not enough will cause major damage to the engine. The oil in the gas mix is what lubes the cylinder/rings against the cylinder walls. 40:1 is way lean of oil for a 50:1 mix engine
Aug 12, 2014 | Garden
Where is the flywheel located on an Echo PB251 gas leaf blower?
Before you go through the trouble of dismantling the blower to get to the flywheel you should perform a compression test. 140 psi is ideal. Less than 100 its probably not worth repairing. Less than 90 it shouldn't run.
Jul 13, 2014 | ECHO, Inc. PB-251C Handheld Blower
I have a PB251 Echo blower that won't start. I have a good spark Good compression and clean new gas is getting to cylinder because i have a wet spark plug when i removed it ,yet it won't even...
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
Aug 31, 2011 | Echo Garden
My Echo PB 235 starts fine, and runs. It will ONLY do so, however, when the choke is on, or about 15% off. Any other position causes the blower to stutter and quit abroubtly. ( ie: Moving the choke to...
Have you drained all the old fuel mixture out? As well as taking out the spark plug and cleaning it should do the trick. I suggest giving it a little tuneup.
Jul 11, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have a PB251 that I purchased from Home Depot as a refurbished unit. It has new plug, carb and all new filters. PB251 runs fine with a full tank, but when down to a half of a tank it stalls out and won't...
its possible the gas pickup tube inside the tank is bent and not reaching the lower tank,this is just a flexible tube in the tank,otherwise,loosen the gas cap when it kills,sometimes they go bad and create a vapor lock
Mar 13, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
ECHO, Inc. PB-251C Handheld Blower Logo
1,954 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
