Question about Miele CVA4070 Coffee Maker
Need a replacement frother wand for Miele 4070
Need to replace the whole cappuccinator
2 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: I need directions to clean my miele CVA 4070
The cleaning instructions are on page 34-45 of the owners manual =>
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback. Thank you.
Posted on Jan 03, 2009
Miele 4070 will not draw up milk to make a cappuccino despite thumping motor sound. No steam is generated and all exterior parts are cleaned thoroughly, regularly. Any suggestions?
First, I'm not a Miele technician, but I've worked on similar table top espresso machines. But I suggest you contact your vendor for service. Check your warranty.
*** Following is just for information***
FYI; There are quite a few you tube videos on this machine.
* These smaller units have individual heaters and mini-boilers instead of one big boiler used in commercial machines.
* I suspect the steamer is a mini-boiler that are common on small brewers. It's about 3" x 4" and 1" thick made of aluminum. There is a heat limit fuse and thermo disk. One or both may be blown.
* If your getting sputtering cold water from the steam wand then it's definitely the boiler other wise it's the vibration pump. Quite a few vids on you tube about the ULKA water pump (suggest alexis c vid)
* I don't think there is any solenoid steam valve on this unit as it's only used on larger boiler systems where the boiler is under pressure all the time. The slow steam start is a good indication of the mini-boiler reheating.
* Final; This is a very compact machine with a lot of wires. Please review the vids on you tube by searching "Miele CVA 4070" Suggest getting help from your vendor as you will need those parts as mentioned.
Aloha, ukeboy57
PS there is a lock out feature on this brand. Check this link for more info:
https://www.bing.com/videos/search?q=Miele+4070&&view=detail&mid=87B4106BEC0DAF1D524587B4106BEC0DAF1D5245&rvsmid=9D76B03F2F848C9C94B59D76B03F2F848C9C94B5&FORM=VDQVAP
Feb 02, 2018 | Miele Coffee Makers & Espresso Machines
Part # for clear silicone tubing and connected plastic orifice on milk frother
Just call Miele .. this is a standard replacement part. Regards
Dec 29, 2015 | Miele CVA4070 Coffee Maker
CVA 4070. Where can I get replacement gaskets and brew unit?
Check with local appliance parts distributor and/or Miele to determine availability and source.
Sep 01, 2015 | Miele Coffee Makers & Espresso Machines
Hi My Miele Coffee System seems to have developed a problem where when i use the steam wand and then close the wand off steam still spits out for about 30 seconds. Is this something i can fix myself or do...
I have the later model (CVA 4070) and the setup is lightly different. I have not worked on your model however I think there are only two parts that need to be checked. 1. Steam Valve (located in door and part of the steam knob). This is the likely cause and the problem is that it's either dirty and can be disassembled and cleaned or it has worn parts inside that need to replaced. 2. Steam Solenoid (inside unit before steam heater). These generally block and thus result in lower pressure but perhaps this one is having trouble closing. If your technically minded I would disassemble steam valve in door and clean and inspect all parts then re-assemble. If this does not fix problem then replace any suspect parts in the steam valve. ie o-rings. Testing 2 is more complex. You could do this via the Service Mode. Please Note ... DO NOT WORK on this machine unless power plug is removed from mains socket. Regards
Sep 01, 2013 | Miele Coffee System
Miele CVA 4066 stopped frothing milk
It sounds like the venturi tube is blocked. Have you ever removed the frothing unit and cleaned in manually? I have a model 4085 and I can reach under where the milk exit tube comes out, twist anti-clockwise (if you are looking up at it) and the whole assembly with the inlet and outlet tube comes out. These pieces can then be individually taken apart and rinsed thoroughly with warm water. If you put it back together (don't forget to twist the connector that locks it back in) and the milk still doesn't froth, take it out again and use a small needle to clear the top of the clear venturi tube which sucks air in to do the frothing. If it is really badly gunged up it might need to be replaced, but mine is 5 years old and still going with regular rinsing. My whole brew unit had to be replaced after 4 years at a cost of about GBP 200, but that's another story.
Nov 21, 2012 | Miele Coffee Makers & Espresso Machines
The wand that connects to the power head at the powerhead connection broke(sheared off) fine crack
Unfortunatley the Wand for your Miele is sold as an entirely assembly only. Miele does not sell pieces of this wand separately. In order to fix your wand you'll need to purchase a new wand assembly complete.
The wand on your Miele is the Miele SET210 Wand. Here's a link if you need to purchase one;
http://www.govacuum.com/miele-172.html
I would probably guess that your wand broke off right at the bottom where it connects into the power nozzle. Unfortunately this is the weakest part of the wand as you can probably see. The wand narrows into a thinner plastic here, and I've seen a few wands crack off right on the bottom part.
Please feel free to request a repair clarification if you have any questions about how to repair your vacuum.
If you found this helpful, please be sure to rate it by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele s558 Silver Moon Vacuum
Dec 11, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
