Question about GE Washing Machines
Ge 6 cycle 2 speed heavy duty extra large capacity bad oil smell
Bad oil like smell
  • 4 more comments
  • Mark Morgan Mar 22, 2014
    FYI my sister in law recently started using a homemade laundry detergent recipe she found on the internet.
    We also just recently ran a cleaning cycle with bleach etc thinking smell was from build up in machine
    Do these type of top loaders have a drain trap on them that could get gummed up?
  • Mark Morgan Mar 24, 2014
    Found oil inside at bottom of machine I think this narrows trouble down to a bad transmission.
  • Mark Morgan Jun 02, 2014
    Found transmission leaking when took off front cover.
    Found transmission leaking when I removed front cover
  • 76 Answers
If you have not recently washed any clothing that may have had oil on it then there are a couple of other causes for this. The start Capacitor could be starting to fail or the transmission is starting to leak.
If the smell is strong then I would suspect the start capacitor the most. You can visually inspect it to see if it is starting to bulge or leak. Let me know if this helps.
Posted on Jun 01, 2014
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
Posted on Apr 12, 2008
SOURCE: Amana Heavy Duty Extra Large
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Posted on Aug 20, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer not spinning/agitat
This problem is usually attributed to a broken motor coupling. The following link provides step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is a small 3-piece component that is installed behind the drive motor and couples it to the transmission. It is common for these small couplers to break as they wear out. The key symptom in determining the cause is the fact the washer will not agitate, but still drains. The reason is because your drain pump is mounted on the front of the drive motor and will still run as long as the drive motor is running. The part number is provided in the link I gave you. A replacement coupler can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best price. Make sure you "Search by Part Number" when looking up the part. This shouldn't cost more than $20. If you do not wish to order on line, take the part number I provided and go to your nearest appliance parts retailer. This is a common item they should have in their inventory.
If you have questions along the way, please let me know. I hope you find this information helpful.
Posted on Mar 03, 2009
landsend
  • 1066 Answers
SOURCE: Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Posted on Apr 01, 2009
GE WBXR1060TAWW, Top loading high capacity washer. I need the specs, capacity and number of speeds?
The (X) in the model number stands for extra large (2.7cu ft) capacity. The 1 stands for single speed. The 6 stands for 6 cycles. It should have a white plastic clothes basket. More expensive models had a stainless basket. Hope this helps you.
Apr 15, 2015 | GE Washing Machines
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE Top loader, Heavy Duty, large capacity washer does not advance cycles but stays in one cycle. I have to manually change cycles.
Depending on the exact model number it sounds like you are dealing with a bad timer or bad clock on the timer. There are contact points inside the timer and they burn out. Sometimes the clock goes bad It has plastic gears inside and is non serviceable. The only thing you can do is replace the timer or call a local repair technitian to make sure.
Oct 26, 2010 | GE Washing Machines
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Year of dryer
INSIDE THE DRYER DOOR IS WHERE MOST MODEL NUMBER ARE OR ON THE TOP BACK OF THE DRYER HEAD,THANKS
Jul 23, 2008 | GE Dryers
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
Jul 07, 2008 | Washing Machines
Washing Machines Logo
108 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
