Question about SingerAAAAAAAA Patchwork TM 7285Q Sewing & Quilting Machine
Winding the bobbin e2
Error 2
    New Friend:
Don't bother with the manual. It says NOTHING about error codes or "how to proceed." Returned mine for another brand. I was getting the e2 message the first time I used it, straight out of the box. People said it was the plug for he pedal not being in all the way. Which was not the case. And some said it was my outlet. Which was also, not the case. I was always a faithful Singer customer until now. After 25 years of using a Singer I'm now so fed up with their lack of quality customer service and quality machines I will never go back.
Posted on Jan 01, 2015
  • Singer Master
  • 1,388 Answers
3 Suggested Answers
  • 1564 Answers
SOURCE: How to fix E2 code on Singer Fashion Mate 5500 sewing machien?
I would take it back right now. Don't wait for another E2 error. I would take it back and get a different brand of machine.
Sorry... but Singer doesn't have the quality it once had.
Posted on Aug 09, 2012
  • 10865 Answers
SOURCE: bobbin winding
http://www.singerco.com/accessories/manuals.html
go to this site and you can request the owner manual which will shoe u exactly how to proceed
Posted on Feb 27, 2009
I'm getting an E2 error message on a Singer 8768 Heritage model.. Re-doing bobbin and bobbin placement but still getting the message.
This answer on Pinterest:
How to Fix Code E2 on Singer Fashion Mate Sewing Machine 7256 eHow
In case you are unable to view--here is the text:
The Singer 7256 Fashion Mate sewing machine has a top drop-in thread bobbin and an automatic needle threader. The digital display on the side of the machine is used to select different stitch settings on the machine. When the display reads error code E2, it means that there is a bobbing threading error, which may be caused by the thread looping or bunching under the fabric as you sew.
Things You'll Need
  • Pen
  • Screwdriver
  • Push the bobbin-winding spindle of the sewing machine back to the left.
  • Turn the hand-wheel toward you, hold the needle thread (thread on the sewing machine needle) and tug it lightly as the needle goes down and then raises up. A small loop will raise up through the needle plate on the sewing machine. Use the tip of a pen to lift the loop up through to the back of the machine.
  • Check the position of the needle. It should be seated in the sewing machine with the flat side facing the back of the machine. If it is not, remove the needle and reinsert it so that it is facing the correct way.
  • Remove the bobbin case. Use a screwdriver to turn the screw on the side of the bobbin until the loops of thread pull taught and are removed.
  • Remove any loose fibers or threads that may be stuck in the tension disks.
  • Reset the upper tension disks. Raise the presser foot lever up. Put the tension setting of the sewing machine on setting "4." Hold onto the spool of thread in your right hand and with your left, route the thread down through the tension channel, around the bottom of the disk and up the other side. When done correctly, the thread will click into place and slip in between the tension disks.
  • Set the thread bobbin in the bobbin case, with the thread passing over the top of the bobbin and then down to the right. Route the thread through the notch located at the left of the bobbin case and pull it through. Move the thread over the top of the throat plate and over to the back of the machine.
Tips & Warnings
  • Using incorrect bobbins may cause error E2 to occur. Not all plastic bobbins are the same size, so check the model number of the bobbin to ensure that you are using the correct one with your sewing machine.
  • Never turn the hand-wheel on the sewing machine away from you, as it will change the timing on the sewing machine.
Singer 8768 HERITAGE Instruction Manual Page 58
Dec 05, 2016 | Singer Heritage 8768 Electronic Sewing...
Error message E2 when trying to wind the bobbin
Difficult to assist without the make & model. Usually the troubleshooting section of the owner's manual has a list of error codes and how to resolve them. You can also search the internet listing: Make + Model + Error Code E2
Feb 10, 2016 | Sewing Machines
Singer stylist E2 error code bobbin winding
I have just repaired a 7258 with a frozen bearing unrelated to the E2 code except that I thought I would lube the entire machine while it was apart, and through my ignorance, I greased the clutch that releases the mainshaft when winding the bobbin, and then when the clutch wasn't working correctly, caused the E2 error. I can say the E2 error is not caused by a plug not seated correctly, too much tension in the bobbin thread, or God having a bad day. The E2 error code is thrown when the bobbin holder is in the wind position, and the mainshaft rotates. There is a clutch just behind the hand knob on the right side of the machine, and if it has too much lubrication with a stiff grease, or on an older machine, if the lube has dried out, the clutch will not release properly. I took the clutch apart, cleaned the grease I put in it, and then lubed it with bicycle silicone oil. It now works as designed. The hardest part of the repair was figuring out how the plastic cases split apart! If anyone in the SF Bay Area has a 7256, or 7258 that gives the E2 code, I can fix it - it's actually kind 'a fun...
Feb 08, 2013 | Singer Sewing Machines
Singer 7258 error e2 when winding bobbin
I had this problem too. What I did was turn the post the bobbin sits on to the left (lefty-loosy) and kept re-booting the sewing machine until the bobbin started to spin correctly and the needle disengaged! I was so happy I figured it out, I did not want to return the sewing machine.
Nov 09, 2012 | Singer 7258 Sewing Machine
Aug 08, 2012 | Singer Sewing Machines
Start sewing and starts beep say e2
try rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
try changing the needle
May 20, 2012 | Singer 7422
SingerAAAAAAAA Patchwork TM 7285Q Sewing & Quilting Machine Logo
557 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
