Pride New Mobility Legend 4 Wheel Scooter Logo
r
rokendra arterberry Posted on Mar 22, 2014
My headlights is not working on my polaris 4x4 magnum 4 wheeler is there a fuse box anywhere how can i fix my headlights please help?
Headlights don't work
Harry Sappington
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Apr 18, 2014
Harry Sappington
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
4403
Points
47
Possible blown bulb. If yours is like mine then you can remove the lens in front to access the bulb. If the unit is still under warranty do not touch it. Contact the place you purchased it and have them replace it. There may be a reason that the bulb blew out that a simple bulb cannot correct.
Where are the fuses on a 2001 Polaris 325 Magnum 4X4
Polaris 325 MAGNUM 4X4 HDS A00CD32FA Parts Manual
www.manualslib.com > ... > 325 MAGNUM 4X4 HDS A00CD32FA
View and Download Polaris 325 MAGNUM 4X4 HDS A00CD32FA parts manual online.Polaris Automobile Accessories Parts Manual. 325 MAGNUM 4X4 HDS ...
Aug 07, 2015 • Polaris ATV
Polaris troubleshooting
no just the caliper, they will try sell you a whole kit but all you need is caliper. the piston on yours is now starting to stick that's why sometimes will work good other times will heat up and begin to burn the pads. this will need addressed asap for if it gets stuck and doesn't release could cause brakes to catch fire. so do it as soon as possiable.
Lights on 1995 Polaris 4x4 magnum worked b4 changing of spark plug now they do not. is there a fuse 4 the lights if so where is or r they located? if not a fuse then what everything else works fine
There is a fuse but I am going toward the little plus that go's to your light that may have come unplugged when you changed your plug. That a bit old look for inline fuse or under the seat?
Oct 01, 2013 • Polaris ATV
I have a 2004 Polaris Magnum 330cc 4x4. It will only start up if i rock it side to side, but when i stop shaking the four wheeler it dies
You need to inspect all gas lines for obstructions including the gas tank , and especially the carb. I can bet dollars to doughnuts that it's a fuel problem something is blocking the fuel and by rocking it it's allowing the fuel to go through. hope this helps , let me know how you make out .
Adam J
My Polaris Sportsman 400 cuts off when i put in reverse and my dash + headlights do not work. Where is the fuse box?
YOU PLACED THIS QUESTION UNDER POOL PUMP, BUT I WILL GIVE IT A TRY. MOST OF THE TIME, THE FUSES ARE IN THE HEADLIGHT ASSEMBLY ,, ITS LIKE THE ONLY DRY SPOT ON IT, OR YOU CAN SEARCH NEXT TO THE BATTERY .. THE CUTTING OFF MAY BE A SEAT SWITCH, PULL THE SIDE COVERS OFF AND DO SOME SNOOPING AROUND, YOU MIGHT FIND A FUSE BOX THAT TELLS YOU WHAT FUSE DOES WHAT.ON THE INSIDE OF THE LID. IF YOU HAVE NO LUCK .. TRY YOUR SEARCH AGAIN UNDER THE RIGHT CATEGORY.. OR DO A GOOGLE SEARCH FOR 4 WHEELER CLUBS FORUMS .. THERE A REAL GOOD SOURCE WITH PICTURES !! AND DON'T FORGET ABUT ME .. CLICK ON THE YES AND LEAVE A REVIEW .. COOL AND THANKS MAN .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA
Jun 17, 2011 • Polaris ATV
4helpful
2answers
I have a 1997 425 magnum 4x4 and am having 4 wheel drive trouble
I had the same trouble , I bypassed the switch in the gear shift box .
Oct 13, 2009 • Polaris ATV
3answers
1995 polaris 425 magnum 4x4 blows the tail and headlight bulbs. replaced regulator..still does it. battery shot. does it have to have a good battery hooked up in order to work properly?
i had a polaris scrambler three wheeler and it would blows bulbs also, it had a junk battery in it, never thought anything of it, read up on it and if the battery has a short in it, it will blows the bulbs, replaced the battery and didnt have any more problems blowing bulbs
Oct 04, 2009 • Polaris ATV
2001 Polaris sportsman 500 magnum 4x4, speedo dont work
I'm not sure but it might be the sensor on the right front wheel disk
May 08, 2009 • Polaris ATV
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
