Question about Miracle MJ-550 White Electric Wheatgrass Juicer
Wheat grass is spinning around the auger on my miracle wheat grass juicer 550 mj
Panasonic MJ- 66PR Juice Extractor
I have a new, in sealed original box, Panasonic MJ-65PR Juice Extractor, I will sell for $70, plus shipping. I'm about to put it on Ebay.
It was given to me as a Christmas present and I never used it.
Contact me at juicer-fll@snkmail.com.
I'm using a temporary email address to avoid spam.
Jeff
Jun 22, 2012 | Panasonic MJ- 66PR Juice Extractor
Juicer squeaks
Using a screw driver remove screws to detach the thing that locks the attachments into place. You will see a rubber seal around the socket in which the auger is fitted. Remove the seal and put a little oil on it. Replace everything after doing the lubrication.
Jan 07, 2012 | KitchenAid Citrus Juicer
No problem. question: can you juice wheat grass with the breville juicer?
Not really. You'll get wet pulp and a big mess to clean, not to mention the waste of your expensive products. Here's why-
Best juicer machines for wheatgrass and leafy greens
Aug 16, 2011 | Breville BJE200XL 700 Watts Juicer
My juicer moves a lot when juicing
They all vibrate no matter what you do. Best solution, costly, is to get a pulp ejection
type juicer. Miracle MJ1000 is a nice little juicer for about $130.
Nov 04, 2010 | Omega 1000 Juice Extractor
I juice mainly green vegetables: kale, spinach, etc, then carrots -and it doesn't have enough power, slows down and then stops - any idea why?
Sorry, but it's not designed for leafy vegetables.
Carrots, apples, celery-yes. For kale, spinach
try a inexpensive, hand powered, wheat grass
juicer. About $50.
Jul 28, 2010 | Acme 5001 Supreme Juicerator Juice...
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
Motor won't work on Champion unless I press on part
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
Jun 27, 2009 | Champion G5-PG-710 650 Watts Juicer
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Jun 22, 2008 | Champion 2000+ Household Juice Extractor
Miracle MJ-550 White Electric Wheatgrass Juicer Logo
21 people viewed this question
Top Miracle Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Miracle Juicer Expert? Answer questions, earn points and help others
