Computers & Internet Logo
Beth Pomerantz Posted on Mar 22, 2014
How to reverse the zoom with firefox
I accidently made the webpage smaller thru my touchpad. How to reverse to 100%
Scroll zone is active but webpages can't be scrolled
It is obvious that the problem is a compatibility problem. You need to post the problem in the Firefox community to get help.
1helpful
Can't seem to zoom back to normal on webpage
Hello Smithette8!
The solution depends on your browser...
Using Firefox:
Click 'View', Click Zoom in or Zoom out or Zoom Reset
Alternatively: Right Click on Menu Bar, Click Customize, Drag icon with Minus Plus symbol to the tool bar, return to the bottom right of the open window, click 'Done'
Chrome allows zoom by percentages, back to 100 is normal. The menu is near the top right hand corner and displays on click.
With the above, should you be using I.E., a little click and view should provide you with the items. If not please let me know and I'll load I.E. and let you know what I find!
Thanks!
Jimm
I was using to touch pad to browse ebay and the font got small. Tried to fix and it got even smaller! Ugg. When I go away from ebay the font is fine but every time I go there the font has stayed small. ...
You must have been using a multi-touch gesture on your laptop by mistake. You can resolve this in two ways:
  1. Just like zooming out on an iPod, place two fingers on the touch pad, and spread them away from each other OR
  2. In your web broswer - IE, Firefox, Chrome, Opera, etc. - press Control and 0 (thats the number zero) at the same time. This will bring you back to the standard 100% zoom.
2helpful
3answers
Just upgraded to the latest version and now every site shows up very tiny. Ran it in safe mode and it was the same. Any way to download an earlier version?
If you know the exact version of your previous Firefox, then you can download it via Google.
However, if you couldn't find it, you may use the current version of Firefox that you have and then hold down the "Ctrl" key and then hit the plus (+) sign. That will make your screen display bigger.
Printer using small type font size when printing from web pages
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
you can use Smart Web printing software to print webpages:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00793678&cc=us&lc=en&dlc=en
also, perform the steps below:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
2helpful
2answers
How does multi=gesture touchpad work Ikeep accidentaly zooming
Just think of it as mouse built into the PC. Use your finger to navigate and the buttons to click
Enlarging print size
if you use Mozilla Firefox for your web browser (click here to go to the Mozilla site) when you print you can zoom in and out if you go to file > page setup the screen below will come up just un click shrink to fit page and enter in a zoom scale (larger makes your text lager & smaller makes your text smaller)
also with Mozilla you can zoom in and out on the page you are viewing by holding down 'ctrl' on your keyboard and clicking the + key to zoom in and the - key to zoom out.
i hope this has been helpful.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
