Question about Sunbeam Renue Tension Relief Heating Pad
High temp button on sunbeam pad wont reset pad wont get hot. is this a problem with controller?
I use this HP every day, sometimes hours at a time! Problem started out with off light flashing and pad not turning back on (has 90 shutoff timer). Could unplug then plug back in, & it would start to work again. After a few days the red high temp light started to blink and wouldn't stop. You couldn't get it to do anything w/out unplugging it. Even then it wont turn back on or heat up. I've had this happen w/other pads, and I wonder if it has to do w/the timer or controller. What can I do to fix this prolem? I buy about 6 pads a year!
4 Suggested Answers
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Posted on Jan 10, 2009
SOURCE: have heating pad model 818-7. blinking red light
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Posted on Dec 16, 2009
  • 51139 Answers
SOURCE: Sunbeam heat pad says it requires 120V ac outlet. I plugged it into every outlet right out the box and have only gotten a red blinking light.
what voltage is recommended for the unit
It it says 120 volts but you have different voltage the it may be damaged from the incorrect voltage
if not the case take it back for a warranty exchange as it is faulty from go
Posted on Dec 28, 2015
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
My GE 24 in Profile PDW8280JSS door wont open: Now the "clean" light is on. I tried cutting power for over an hour, I have run wash cycles, the lock handle will not move. The unit did not have...
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 04, 2011 | Dishwashers
How do I reset kitchen aid dishwasher with the clean constantly flashing? dishwasher won't start.
Hello, push the following buttons on your control panel.......Heated dry then High temp wash, heated dry then high temp wash, heated dry then high temp wash 3 times within 5 sec you will see the control panel all light up then you should be good to go. The reason it has failed is it has exceeded alloted time to heat the water to temp selected . The best thing to do from now on is to run the water at sink until hot then start the dishwasher more so in winter than summer.
Fixrguy
Feb 13, 2011 | Dishwashers
I own a Bradford White Corp. Electric Hot Water Heater. It has two thermostats, one upper and one lower. Model # M-1-40S6DS 13, ser# XK0300351. My problem is the red button on the upper control trips...
Hello. If you turn off the power and drain the tank then examine each of the heating elements you will find that the upper element is deteriorated. The fix is to replace the heating element. Actually though my practice is when one is bad the other isn't far behind so for a few dollars I change both when I have the tank drained. Joe
Feb 28, 2010 | Water Heaters
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
New heating pad not working
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Sunbeam Renue Tension Relief Heating Pad Logo
26 people viewed this question
Top Sunbeam Health & Beauty Experts
Kevin Hill
Level 1 Expert
musquodoboit
musquodoboit
Level 1 Expert
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
