Question about Hotpoint First Edition WMA22 Front Load Washer
Water cannot pass into the machine.
Water is not entering the machine to wash the cloths, what is the likely problem.
    New Friend:
    Problem Solver:
  • 10 Answers
1st: make sure water valve is open
2nd: make sure there no kink in the hose:
after these to and still same problem..
more than likely you will require new module
Posted on Mar 24, 2014
2 Suggested Answers
  • 330 Answers
SOURCE: Washing machine wont circulate the clothes, the thing inside wont move
Check the belt, either loss or broke
Posted on Jul 03, 2008
There is not enough water in my machine?
On mine, it does not swim clothes in water, but certain parts of the cycle, you do see water in the machine.
1) are the clothes damp at the end of the wash?
2) more importantly, are the clothes clean?
3) do you see / hear water enter on cycle start?
My suggestions:
1) loosen / remove the fill hose and verify you have water pressure in the fill hose.
2) read on this forum for test cycle proceedure. Run tests.
3) if it truly had no water, I am sure there would be an error code. Look that code up.
4) Download the manual, and follow their test / fix steps.
Note: the test proceedure, error codes and manual are mentioned by helpers in posts where I have had questions. See if you can look up my previous posts.
Blessings,
Darryl
Sep 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Does not sense clothes
most top loaders fill to the setting you enter into the program l( medium low high etc ) as the clothes absorb the water it will keep filling until a level is reached at which point that is the amount of water for the clothes and the machine will start you just have to think about how many clothes you are washing and how big they are ie blanket will be a big load and nickers will be small load
Jun 09, 2013 | Washing Machines
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
Mar 11, 2012 | Simpson Washing Machines
Water entering washing machine after cycle finished & clothes removed?
That sounds like an inlet water control valve is malfunctioning- or the control board. If you remove power from the machine and water still enters it is more likely to be the valve and a call to your local service engineer. Sorry ;-0(
John C
Feb 27, 2011 | Kenmore HE2 Plus Front Load Washer
Working half a minut and stop
It could be a number of things: no water detected entering the machine, wrong temp water entering machine, water hoses crossed, door not closed all the way, items jammed between the tub, too little clothes, too many clothes, and me fave: unbalanced load.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 24, 2011 | Washing Machines
My clothes are still dripping wet after a complete cycle.
If the washing machine is not spinning to its regular speed then it can be the cause of wet clothes.If there is any cloth got stuck in between the inner and outer tub then this will slow the speed and this can cause the problem.Also if the washing machine spin motor,if its faulty then it can be the reason for clothes coming wet.Also check the motor coupler,if its cracked or broken this can be the reason of motor not spinning to its full speed. --------- But if all this ----- the motor,the motor coupler and the inner tub and outer tub blockages checked ok.And there is no problem seen then the other possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.So the clothes come out wet,because some amount of water will always enter the washer due to faulty water inlet valve. --------- This are the possibilities that has to be checked and confirmed for the problem to be solved.To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore Washing Machines
My washing machine is leaving a lot of soap in the clothes. Why? It started with the machine not stopping a couple of times. It`s now stopping but there`s a lot of soap in the clothes.
Sounds like not discharging water properly..You could try cleaning the filter/ also could be cold water not entering machine during rinse..Hope this is of some help .
Nov 12, 2009 | Washing Machines
Maytag neptune washer
check your cold water filter at the valve where it enters the back of the machine make sure cold water enters the machine.take the cold hose of and make sure it is clear.
Oct 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint First Edition WMA22 Front Load Washer Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
