Bush TV set up colours look like looking through night vision lenses.
This is a new TV that we are trying to set up and the colours are strange like looking through night vision lenses, if we set the contrast to 9 and play with the colour and brightness and set the sharpness for 28 then we can clear it up but it looks like everything is set at twilight rather than in sunshine where colours are meant to be vivid. We are not connected to aerial but we don't watch TV just DVDs and play games? Any ideas? TIA
  • 790 Answers
Try to reset the unit to factory default settings.
If the TV is under any kind of warranty, return it while you can.
Also, without knowing what kind of TV, Plasma, ect. it is had to pin point your problems.
Hope this helps
Posted on Mar 22, 2014
Testimonial: "its brand new lcd tv, only got today, but never had this kind of problem before to adjust picture quality, trying to do it manually if you try to brighten the picture its like little splashes of light appear at certain areas all over the screen"
  • Melanie Kinloch
    Melanie Kinloch Mar 23, 2014
    ive tried various things, such as trying to retune and adjusting manually, Ive left it turned of and retuned again, looks like its going back, thanks for the help John Ray :)
bernardlunda
  • 318 Answers
SOURCE: JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Posted on Mar 28, 2009
  • 19 Answers
SOURCE: female coax connector in tv bad?
Did the cable person take a reading on the signal level at the cable outlet on the wall and did the cable person check the TV setting to make sure they are correct. TV could be set on the wrong channel also.
Posted on Nov 09, 2007
Shuttle83
  • 1139 Answers
SOURCE: sharp tv audio problem
You may have a tunner problem. Try this turn your TV to channel 3 connect you cable to it and select a channel. If thesound has a problem what may be happening is the the audio detector may not be working properly or the audio amplification stages may not be working correctly from the audio detector. You will have to test the audio stage from the detector to the last audio amplifier to troubleshoot this problem. If you have experiences in this that's good if not take the set to a qualified service technician.
Posted on Sep 18, 2007
SOURCE: i just installed my cable box ( motorola ) onto my
Sounds like it is connected up wrong? are you sure the correct colored cables are used and in right Jacks etc? OR maybe the PAL, NTSC format needs changing?
Posted on Feb 15, 2010
SOURCE: My vizio tv is making a buzzing noise when I watch
Hi, Mary with Dish Network Customer Service. I had this issue with my TV as well. You will need to turn the TV volume up and the cable volume down. The opposite way from how you have it now. This should resolve your issue.
Posted on Jan 26, 2011
I want to change my Bush 32" TV to HDMI without my remote!
You need to go to main setting on the side of the TV where the power button is there should be a setting on input.
Thanks you
Nov 04, 2013 | Bush Visions 32" Flat Panel Corner TV...
My bush lcd tv keeps frezzing and lots of colours come on?
Please look for loose contacts in RC jack, cable and connectors. Try changing the input device to some other and see.
Aug 16, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Bush bled42fhdae led tv colour calibration is wrong,emphasizes majenta too much
White balance maladjusted. Adjust it properly. If you wish to get some details; visit the site linked here. Pull up older posts.
Aug 11, 2017 | Televison & Video
Tint has come away from lenses
Hello, do you mean that lens coating fell off? I hope not, but who can say when these Night vision monoculars and binoculars are soley manufactured in Russia. Hint: auction it on eBay. US Night Vision Optics will not warranty the lens coating, sorry. GB...stewbison.
Dec 01, 2010 | US Night Vision D-343 Monocular
Colour breakdown
Thank you for your reply. I have since had my TV repaired by a local engineer. The TV needed a new part to restore the colour.
Helen Shaw
Jul 06, 2009 | Bush Televison & Video
Bush tv has a circle on screen like looking thru a telescope
HELLO
Funnily enough I have been given a 21 inch standard Bush set with the same problem!
It's a DEGAUSSING fault. This means the deguss circuit in the TV is not operating as it should - probably a faulty positor. When you switch the TV on (NOT FROM STANDBY) the circuit that removes magnetism from the screen does not work correctly.
Switch it off, unplug the set from the mains for 30 minutes or so and try it again. If there is no change, contact a TV repair centre.
Make sure there are no hifi loudspeakers next to the TV or a radiator as this can have an effect too.
ALL THE BEST! (:-)
Jan 06, 2009 | Bush 5693D 24" TV
Bush TV, model number RF6685VPL/A - Colours are wrong!
It seems that it is a degaussing problem. TV sets have a degaussing coil that when the TV is turned on , it automatically demagnetizes the screen. Never place any speakers or anything magnetic near or on top of your set. if you see swirls of color and like you say, wierd colors, it is that the screen is magnetized. Turn it on and off with the switch. Not the remote control. The degaussing coil only works by manually turn the switch on and off.
Nov 19, 2008 | Televison & Video
Bush RFT TV
try the thermistor degauss coil,
Mar 13, 2008 | Bush 5693D 24" TV
Tv will not turn on when you press the main power button
sounds like the line output transistor is shorted look for a repair kit for your model
Nov 04, 2007 | Bush WS6671 28" TV
Yukon night vision monolular 4x50 lense
Try to jank it left-right and simultaneously try to force it back to threads (either pulling or pushing). Don't hit it with anything since this may damage the insides.
Oct 10, 2007 | Yukon NVMT 20040WP Monocular
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
