Question about Milton Bradley Bop It Extreme
Hasbro bopit extreme "spin it" wheel is sluggish
The red "spin it" wheel is too slow. It looks as if the wheel is leaning slightly towards the plastic housing. It's been doing this somewhat for awhile, but after a few hard attempts to spin (warming up??, it would work ok. Now, that won't even work. How can I realign it so it won't be rubbing the housing? I'm afraid to take it apart because it seems as if putting it back together might be rough. (Once all unscrewed, the inner parts apparently pop out.) I'm tempted to shave the housing a bit so it will spin, but worried shavings will get inside, making matters worse. Maybe slide something between the wheel and housing and pry it up, but then worried about denting the plastic in the process which might make it stick more than it does now? Heat housing with a blow dryer and bend it away from the wheel? Rub some silicone or Wd40 on the housing or wheel or could that just cause it to goop up, making it worse? I've tried sliding a covered razor blade in both sides hoping to clear any debris, but nothing there. I'd be grateful for any advice because as it is now, it's useless, and it's my kids' favorite toy. :( Thanks!
  • cursichella Mar 22, 2014
    Here's a picture of the same model: http://upload.wikimedia.org/wikipedia/en...
    p.s. It's actually called Bop It Extreme, not Bopit
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
I think you should put some oil on it and while you put the oil an it turn it as well ok
Posted on Mar 22, 2014
Testimonial: "You don't think that might goop up or interfere with the electronics?"
How do I get instruction manual for Hasbro bopit carabiner edition
Use google search and you can download the PDF from the results. This was previously answered for you.
May 20, 2015 | Hasbro Bop It Mini Carabiner Edition
How do I get a manual for this?
http://www.hasbro.com/common/documents/87e9fbe8d56fe1124784f6d2788f8ce8/F428F8AD5056900B10AA35D2FE45F258.pdf
May 20, 2015 | Hasbro Toys
Spare part bopit extreme
So do I! Did you ever find one please?
Jul 18, 2013 | Milton Bradley Bop It Extreme
Random multiple misfire code. Cat gets glowing red hot. Sluggish lack of power/acceleration
Combining the hot cat converter and the missfire code, I would lean toward a fuel problem. Too lean or pressure too low.
If it was an ignition problem the cat would usually not be hot.
If the exhaust was stopped up, you would not usually get the multiple missfire issue. Just lack of power.
It could be a leaking EGR or other vac problem, and a dirty fuel filter too.
Jan 23, 2013 | 2003 Chevrolet Cavalier
2006 Honda XR 125 L - 5
Check calipers and seals clean and free the brake pistons if any seals are pinching replace them
Jan 26, 2012 | Honda XR 125 L Motorcycles
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
Changed rear disk pads on 04 explorer and not passenger side rear wheel is smoking driver side is fine? what should I be looking for?
I would lean towards the caliper being frozen up on that side. When its hot take the wheel off and see if the rotor is really hot (CAUTION IT MIGHT BE EXTREMELY HOT) If it is, time to change the caliper.
Apr 07, 2010 | 2004 Ford Explorer Sport Trac
Tub is leaning down slightly to the right and slightly downward
Dear Hi, The reason for the nuisance is that the vibration mount on front end of the tub is worn out and you need to replace the same. you can DIY but its better if you take a technical help with someone who knows how to change them. Replacing the vibration mounts will solve your problem. Make sure that you replace both the mounts as otherwise it may again lead to unbalanced mounting and you may have the problem again too soon on the otherside.
Mar 23, 2009 | Washing Machines
Milton Bradley Bop It Extreme Logo
116 people viewed this question
Top Milton Bradley Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Milton Bradley Toy Expert? Answer questions, earn points and help others
