Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I have a DC07 Animal Vacuum It works and sucks but the beater brushes do not turn Can you help me
Make sure the setting is on carpet and not on bare floor. The brushes will not turn when it is on the bare floor setting.
Posted on Jun 27, 2009
I have no suction from the bottom
If there are no obvious air leaks, check to see that the belt that turns the beater brush is not broken and that the beater brush has not frozen up. Remove the beater brush and clean it, spraying a bit of WD40 at each end by the hard rubber pieces that hold it in place. Turn the beater brush by hand to be sure it moves freely around the rubber pieces. When you reassemble, make sure the belt is properly installed.
Oct 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
THE BRUSH ISN'T TURNING, EVERYTHING ELSE IS WORKING.
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly.
Sep 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc17 animal stopped sucking. brush still
Make sure the flexible hose that connects the beater brush housing up to the connection up by the dust bin is still connected. It could also have a hole in it so check for that as well.
May 23, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar not working
Hi its Darran at Dyson.
If the brush control has been switched off the brush bar won't go round when the vacuum cleaner is lowered into the vacuuming position. If this is in the correct position, we would recommend checking the brush bar and cleaner head for blockages as this can prevent the brush bar turning.
If none of the above resolves the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Many thanks
Darran
Dyson Customer Service
Apr 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Belt drive not working. Won't turn beater brush.
You need to replace the belt. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
Jan 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater brush does not work. Brush is clean and belt is not broke. Dyson 07 animal vaccum
Even though the belt may not be broken it might be stretched and if that is the case it will not turn the brush. You can get replacement belts here:
Dyson DC07 Replacement Belts
Nov 16, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar sucked up corner of throw rug and now it doesn't turn.
Take the head down and clean the brush and when you put it back together it should be back in sync.
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater will not turn .belt is o.k.
your belt is not ok if the brush won't turn. you will need to replace the clutch assemble inside because their are two belts and they are built into that. This was a terrable design flaw with dyson vacuum and its not the only flaw.
May 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Apr 02, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal
Happened to me too. there is a reset somewhere, i got mine working again. try the Dyson website, sorry
Mar 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
360 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
