Question about Furniture
The arm on my phonograph moves to the center of the record and does not play.
When I place the arm of the phonograph player on the beginning of the record... it immediately slides to the center of the record. I've placed weights on the arm to keep it from sliding. it didn't work. what next??
5 Suggested Answers
  • 8 Answers
SOURCE: AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Posted on Aug 18, 2009
STYLUSCITY
  • 271 Answers
SOURCE: What is the removable black disc for,and why does
Hi, the black disc is a spacer for use with records that have a large hole in the centre designed to be played in a jukebox. Have you removed the stylus and checked the tip. It sounds to me like the tip has broken off. Cheers John. Styluscity@gmail.com
Posted on Aug 09, 2011
  • 298 Answers
SOURCE: The tone arm on my record player slides to the center of the record
usually there is sort of spring loaded screw situation under the tone arm
specifically for that purpose
Posted on Jan 30, 2012
Grubhead
  • 5056 Answers
SOURCE: I have a magnavox micromatic record player that
Is this an old 60's model?
If it is you can find some videos on servicing them on YouTube.
Posted on Nov 20, 2012
How do i get the turntable to work on the thomson th632
Move The Tone Arm Over The Record And This Turns On An Internal Switch Wich Starts The Motor On The Phonograph And The Record Will Play !
Nov 16, 2014 | Computers & Internet
How does one get the phonograph to work? I can't find the manual and I can't get the phonograph to start rotating.
if you have it plugged into the power source,and cannot see an on/off switch, it may well start up by moving the arm onto the record
Dec 26, 2009 | Audio Players & Recorders
AT-PL50 won't play
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Tone arm moves to the middle rather than the beginning
There is 33and 45. that's the size of the record.There should be a level to change from one to the other.
Aug 07, 2009 | Sony PS-LX250H Turntable
The Radio,Cassette Player/Recorder. and CD Player all work. The Phonograph Does Not!
if it arrived by mail then the sender might have screwed the transit screws down to avoid damaging the phono , i am not familiar with memorex but if like most turntables there should be some big screw heads visible on the top of the phono or possibly even under the platter all you have to do is unwind the screws until the platter unit moves freely [you should be able to push it up and down a little bit ]
May 23, 2009 | Audio Players & Recorders
Playing to the end of the record
I LOVED the 40bs, and if you look at the size selector, which is located at an angle to the right side at the front along with the manual or auto setting in the front. There are 4 settings, 78-10, 45-7, 33-12, and 33-7 for the speeds and sizes of the recordings.
Apr 14, 2009 | Teac AG-V1050 Receiver
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Furniture Logo
70 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
