Question about WISE WD120AB-710 - Folding Deck Chair - White - 30H X 26W X 24D WD120AB-710
Safety latches How do you use the safety latches to keep the chair from folding up? The holes on mine appear to be drilled in the wrong place and we can't figure how to use the safety latches.
Should I get a wooden or a plastic chair?
It depends on your preferences. If you are goingfor the plastic one, you have to make sure it meets all the safety needs,especially if it's a folded chair.
May 29, 2012 | Baby Gear
Front seats recliners won't "click" in the upright position.
personally i would pull the seats and weld them into a position that is comfortable both sides of the seat should be welded. a small mig welder would take care of this issue nicely and permanently ! .. jay Florida
Nov 10, 2011 | 1986 Chevrolet Camaro
Trunk lid wont open
Most likely, the plastic snap on the end of the hooked link that runs from the button mechanism down to the latch has popped out of its hole in the latch. Common problem on cars of this age.
If you have fold down rear seats, crawl in the trunk and pop up the plastic snaps that hold the trunk liner in place (if you break some, no worries, they are cheap), and pull up the liner and reach inside and release the trunk latch. Then you can replace the plastic snap on the link, or just secure it to the lock with a zip tie. We bought a new snap and still had to secure it with a zip tie.
If you don't have fold down rear seats, you will need to remove the license plate and drill a hole so you can reach in with a wire hook and release the trunk latch. You need to find a rubber body plug an inch or so in diameter and then drill a hole to fit your rubber plug. This will be easier if you know someone else with an e36 who will let you pull off their trunk lid lining and see what it looks like so you can select the best spot to drill the hole and know just how to grab and pull the trunk latch to release it.
Mar 12, 2011 | 1997 BMW 328
Dont know how to close bebecar multipla sport
To fold a Multipla chassis, you must first lock the swivel wheels in the non-steering mode and ensure that the adjustable handle is in one of the middle positions. To fold it, firstly press the red button and simultaneously, turn the handle collar, in the middle of the handle bar, in the direction of the "FOLD" arrow, and the chair will begin to close. Next, operate the secondary safety device by pulling upwards the plastic tab situated on the right hand side. Tilt the chair forward and continue the folding action until the chassis is fully closed. If you want to store the pushchair, fold the adjustable handle down. Find out more by asking service@bebecar.co.uk for a user-guide.
Sep 26, 2010 | Toys
I can not fold my bebecar raider at stroller
Firstly, remember to lock the swivel wheels in the non steering
mode before folding chair.
To fold, firstly press the red button and simultaneously, turn the handle collar in the direction of the
"FOLD" and the chair will begin to close.
Operate the secondary safety device by pulling the plastic tab.
Tilt the chair forward and continue the folding action until the chassis is fully closed. Why not ask for a user manual at service@bebecar.co.uk
Aug 25, 2010 | Bebecar Raider AT Stroller
How do I unfold my Reebok 8700 i fit? I folded it
Hello there, If you stand behind the machine you should see the safety latch mechanism (round knob on the long section in the middle when the unit is raised) You will need to push up slightly on the walking belt section while pulling out the knob located on the safety rod. While pulling out the knob lower the unit about 3 inches and then release the knob. If you release the knob too soon it will catch back in the hole again. This should release the unit.
Good Luck! Tim
Feb 12, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Removal of tray on Safety 1st high chair
go and chek the mainual of the chair
Mar 12, 2009 | Baby Gear
Bolt broke that holds saftey seat latch on - where to get parts?
one of the best places my be a Automovtive supply stores , you may also try a Home improvement store, they tend to carry "odd" Bolts, to remove the broken bolt you may have to drill it out with a special drill tip also avaliable at most of the Home Improvent stores,, make sure you take your broken piece with you if you still have it so you can get a perfect match.
Jan 31, 2009 | Jet 3 Ultra Power Chair
High chair
When putting the straps into the seat, make sure that the flap is unfolding over the hole, making it lock into place. Also, once you fasten the straps around both the bottom and the back, make sure you pull them as tight as you can around the chair, which helps limit the amount of movement.
Jan 31, 2008 | Peg Perego Culla Carriage Stroller
WISE WD120AB-710 - Folding Deck Chair - White - 30H X 26W X 24D WD120AB-710 Logo
393 people viewed this question
Top WISE Garden Experts
Dennis Key
Dennis Key
john h
Are you a WISE Garden Expert? Answer questions, earn points and help others
