Question about GE Monogram® ZET1PLSS Dual Single Oven
Oven light stays on all the time even when oven off.
    Problem Solver:
  • 12 Answers
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Posted on Jun 03, 2014
2 Suggested Answers
Powerman
  • 68 Answers
SOURCE: GE Stove:
The symptoms suggest that the control relay has welded contacts. This was a result of the element failure producing a surge of current. You will need to replace the electronic control. Another possibility is to contact the folks at www.cgiltd.com.
They offer a repair service.
Posted on Jan 22, 2008
The bottom oven light and heat is on all the time can shut off
Faulty switch if Oven light has a switch, some ovens light stays on, some oven lights switch.off when door closed. As to Oven being on all time , Faulty Switch.
Mar 13, 2015 | Ovens
Did you try the light switch on the control panel? If it's turned on, the door plunger will not turn the light off.
Oct 01, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
My oven pilot light will not stay on
you may need to replace thermocouple and re-try it....good luck.
Nov 06, 2012 | Southbend S560DD (Gas) Oven
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
The lower oven light will not go off and the door seems to be slightly ajar but even if i hold the door closed and then hit the light off button, it still stays on....?
At times the door will slightly come off track.Gently lift up on your oven door and try to glide it back on evenly.
Mar 19, 2011 | Ovens
My indicator lilght stays on even when the burner is off.
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Dec 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Oven not heating up.
fault is the circular element found the fan. take back plate off inside oven and element is exposed. often but not always, you can see the damage to the element. element is easy to replace - usually held in by 2 - 7mm nuts on posts from the element base plate
Jul 06, 2008 | Stoves Ovens
GE Monogram® ZET1PLSS Dual Single Oven Logo
157 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
