Question about Brother Dcp-7055 Laser Print Copy Scan 2400 X 600 Dpi Scan 20 P
Cant detect new toner even replace new toner - Brother Dcp-7055 Laser Print Copy Scan 2400 X 600 Dpi Scan 20 P
  • 4 Answers
Open front cover,,,then press clear start botton at same time,,,no dispay.....press + ten times ,,,ok,,,accepted comes n no message in display
Posted on Mar 28, 2014
Erroro19
E019 0000 Waste toner full detection The waste toner full state was detected.Replace the drum unit.
0001Waster toner full detection sensor is faulty. . The waste toner full state was detected continuously for five or more seconds while the main motor was turning.
- Check the connector of the waster toner full sensor. - Replace the waste toner full sensor. - Replace the DC controller PCB.
Mar 10, 2011 | Canon iR 2016i Black and White Copier
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
I have samsung ml 2010 printer. i always get the message install toner cartridge. but it has a lot of toner it. ihad open it and saw a lot of toner
there is a problem with the detection of toner, could be:
  • the toner cartridge not set in the printer correctly
  • the toner cartridge is faulty (replacing the cartridge may fix)
  • a part in the printer is faulty and is not detecting the toner, or toner cartridge
I'm not exactly familiar with where the toner is detected but you could use an 'air brush' to clean the printer, as perhaps the part that contacts with the cartridge is dirty. You could give the toner cartridge a little side-to-side shake as this may even out the toner and activate the part that detects the toner.
Oct 30, 2010 | Samsung ML 2010 Laser Printer
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Replaced toner but continues to say replace toner&power failure 8
Anthony here. Had a similar problem, fax didn't detect the new toner. The photo sensor does not detect the toner en the fax is new. Put a black tape where the toner slots into the sensor en walla it worked. When the copies become faint I know that the toner is low or over.
A.K (Nairobi, Kenya)
Jul 10, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
ML-1640 Series + Toner exhausted.+ how to reset the printer.
Jun 09, 2009 | Samsung ML-1640 Monochrome Laser Printer
False detection of toner low
The only remedy you have now is to change the sensor , for this you have to refer to the product manual you can download it from
http://www.brother.ca/en/products/pdf/QSG/HL2030-QSUG.pdf
Good Luck
Dec 05, 2007 | Brother HL-2030 Laser Printer
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
Brother Dcp-7055 Laser Print Copy Scan 2400 X 600 Dpi Scan 20 P Logo
54 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
