Question about Panasonic TCP46C2 46 in Plasma TV
Horizontal Band of Thin Red and Blue Lines on Screen
Panasonic Viera 46" Flat Panel TV Model TC-P46C2 The TV works, video and audio. The problem is there is a horizontal band of thin vertical red and blue lines across the screen. This band is a few inches in height - thin vertical red lines, then vertical blue lines, red lines, blue lines across the width of the screen. The band is a little lower than midway (top to bottom). Thanks for your help.
  • 35 Answers
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Posted on May 13, 2014
Raditronic
  • 196 Answers
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
Posted on Apr 22, 2010
SOURCE: right half of screen black
This is a very common problem with this Panasonic set where half the right side is bad and the other half is good. This has been traced to a general plasma panel defect in the manufacturing precess. The panel lasts only about 1.5 years and they go bad. The only solution is to replace the plasma panel. The charges for the cost and labor will double the original prize of the TV set.Good luck.
Posted on Oct 29, 2009
  • 25 Answers
SOURCE: 5 year old panasonic viera
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Posted on Jul 05, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
Posted on Jun 08, 2012
SOURCE: Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Posted on Jun 29, 2012
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
Blue & red horizontal lines in plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 18, 2016 | Panasonic Viera TC-P50G25 50" Plasma TV
How to troubleshoot when tv won't turn on and pwr supply is good?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 18, 2015 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
How to diagnose issue with my panasonic plasma tv
Contact the authorized service center for Panasonic.
Aug 19, 2015 | Panasonic Viera Plasma TV TC-P46C2
A horizontal band of green and red lines across the screen
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Panasonic viera tc-p65vt25 has 3 thin vertical lines red green blue
Check for any loose connection to its COsF to display panel. Contact any service technician. If you wish to get more details, check the site linked here. Screen-shots to defective plasma are given. You cam compare it to that of yours, and can make sure about the fault. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 23, 2013 | Panasonic Televison & Video
Flashing Red Light
One blink is not taken as fault codes to Panasonic. You have to contact the authorized service center.
May 30, 2013 | Panasonic Viera Plasma TV TC-P46C2
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TCP46C2 46 in Plasma TV Logo
1,905 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
