Question about Omnitech 10-Sheet Micro-Cut Shredder
Omnitech shredder ot-nxc18pa won't power up
Shredder plugged in won't turn on
  • 20 Answers
Dear Bruce,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that senses if the paper has been introduced to the shredding slot.
These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing.
While disconnected from the power, try to check if the switch is working properly. Check if you can hear a "click noise" while moving it back and forth by using a paper clip. When this sensor arm is broken, the device will not operate since it does not detect the presence of a paper sheet to be shredded.
Make sure your power is on (not only connected to the wall - but check if there is any indicator in the shredder). If the arm is not broken and you still hear the click noise indicating the micro switch is being activated, then your problem could still be the power since there is not LED indicator in the panel of this device.
If this does not solve your investigation process, please make sure your power cord is fine. Otherwise, it would be an internal electric problem in the device.
One additional possibility (since I have no further details from you) is that the device is on, you can hear the motor running but the gears that move the shredder blades are broken (that has happened to my device).
I hope this gives you some light in further investigating your problem.
RC
Posted on Jun 17, 2014
My Omnitech 12 sheet shredder is barely 6 months old and will not even turn on.
check the warranty period and if within that period take it back for warranty repair or a new one
Dec 20, 2015 | Omnitech 12 Sheet Cross Cut Shredder
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Omnitech 10 sheet shredder keeps running constantly after a page or pages have been completely shredded. I have to stop it and start it manually.
Shredders have to be cleaned periodically to remove bits of paper that may be blocking the sensor that detects when paper has been inserted. If you turn the shredder mechanism upside down, you can see the bits of paper and, with power off, you can pick them out. I find tweezers are a useful tool for this
Dec 13, 2012 | Omnitech 10-Sheet Micro-Cut Shredder
Is there a sensor for Omnitech shredder OT-NXC18PA? if so where can I locate it?
I have this same shredder and same thing happened to mine just 2 months after warranty is up. I called the company and told the sensor is gone and there is no way to replace. BTW mine runs in reverse but not forward.
Jun 24, 2012 | Tech Solution Office Equipment & Supplies
My omnitech shredder OT-NXC8PA stopped working after clearing a paper jam. Seems the machine is running, but not sucking papers.
I think you just fried your gears. The motor is fine, but the gears that connect the motor to the shredding mechanism have had the teeth flattened up. No teeth on the gears = not shredding papers. The gears are made of plastic anyway.
Jun 26, 2011 | Aurora Electronics AS1015CD Cross-Cut...
I have an Omnitech OT-535BL paper shredder. It got a jam, I cleaned the paper out but it still wont work. It sounds like it is turning on when I plug it back in but it wont go.
This unit can also overheat and automatically shuts down when it does; to be thorough--simply unplug, empty the wastebasket, turn upside down, remove any remaining paper from blades, plug back in, and leave it alone for 30-60 minutes. Try again.
It's not an industrial shredder and has a low daily capacity, designed only for small office use.
May 02, 2008 | Computers & Internet
Omnitech 10-Sheet Micro-Cut Shredder Logo
519 people viewed this question
Top Omnitech Office Equipment & Supplies Experts
ray gallant
Are you an Omnitech Office Equipment and Supply Expert? Answer questions, earn points and help others
