Question about Cooktops
Electrulux inductio cooktop E92 error code
Everytime I turn on my cooktop, I get an E92 error code. It will turn on eventually after 6-12 tries....any ideas
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Electrolux Cooktop Hybrid error E07- sometimes, cooking gets interrupted with E07 code and shuts off the panel. On next turn on, usually works okay. Could you describe me the error code? Thanks!
I appreciate your post, friend!
I see that you are having an issue with your Electrolux cooktop displaying a "E07" and shutting off. An "E07" code stands for an issue with your key sensor timer and this could be a potential problem with your right, left, or center board. This may not be a simple DIY job and I would highly recommend having a professional technician come out to diagnosis your cooktop. The technician will have the appropriate tools needed for properly diagnosing your cooktop. This step will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 19, 2015 | Electrolux Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
What do error codes E51, E52, and E53 indicate?
This link lists the error codes for your cooktop: Needapplianceparts com
Specifically, it's a "sensor break" in your front and center burners.
The solutions they recommend:
* Verify element temperature sensor is correctly connected to the generator circuit board
* Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature
* Replace associated generator circuit board
Jan 12, 2014 | Electrolux 30" Electric Hybrid...
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Wolf electric cooktop
This is what Sub-Zero has to say (sounds like techno-gibberish)
Looks like it's technician time -
CT Induction Cooktop Error Code E13
Jan 04, 2018 | Cooktops
Error code F153
Did anyone ever find out the solution to this issues. I have the same f153 fault code and want to know how to solve this
RLA
Jul 17, 2008 | GE 30 in.JP950 Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
