Question about Makita Model Dcs 6421 Chainsaw With 20" Bar & Chain - MKA DCS6421 20
Won't start Won't even catch. Just rented it from Lowes and don't have a manual. Any ideas?
    New Friend:
    Problem Solver:
  • 16 Answers
Sounds like the starter pawls are not engaging.
As it's a hire machine you should take it back and swap for another. If you tamper with it and something breaks then you will be liable for any damage.
Posted on Apr 19, 2014
I have a tiller from lowes, it starts but won't run.
check that you have good fuel flow to the carb. if it has a fuel shut off valve make sure it is open all the way.
Feb 15, 2013 | Garden
My car will not go over 55 mph/3rpm even with the gas pedal pushed all the way down. It also kind of catches when getting going.
I have to ask
Why are you even driving a car that has
whatever that problem is & doing so for
weeks or longer?
Surely you know that you have somewhat serious
issues, when a car won't go over 55 & gets worse!
What does catching mean?
Now it won't start or catch or go
over 55
When are you going to a repair shop?
Before you ruin something or have a costly repair?
Nov 15, 2012 | 2007 Chrysler Sebring Sedan
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
I have 1985 Sega hang on......plays but won't
I don't think Hang On has a DIP switch for gear shifting or speed, it sounds like you may need to calibrate or replace some of the controls. Here is a link to the owner's manual.
http://www.arcade-museum.com/manuals-videogames/H/Hang%20On.pdf
May 11, 2012 | Sega Video Game Consoles & Games
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
We are renting a house built in the early 50's and unfortunately, the stove is also that old. Its a Maytag model # M6131 CPA. The oven does not work and until recently, two of the three burners would...
STOP >>> CALL THE LANDLORD.. its his/her problem.. explain the stove lights itself... even if you are not at home.. that should get his attention... (Fire hazard!!!!)..
Jun 19, 2017 | Kitchen Ranges
I went out to move my 2005 cavalier and when I shifted from reverse to drive, it slipped right thru everything and wouldn't catch. It wouldn't even catch in park. I pulled the parking break and...
I don't know beans about automatice transmissions and the average person can only check the fluid levels and take it to a transmission shop if it is more serious.
As far as the engine goes, you need to localize the problem because with the other indications it might not be the normal stuff. So, what I would recommend is that you take the serpentine belt off and try to turn the crank with a large wrench (CW only) with the car in neutral. If you can turn it, then it is probably not your engine freezing up. If it won't turn then the transmission is probably not disengaging from the flywheel - maybe the torque converter.
If it does turn over, then you can put the belt back on and try to jump start the car with another vehicle or the boost function on a battery charger. It it starts then you know to look at the charging system - battery, alternator. If it doesn't start then the starter or the starter reley.
Sep 06, 2011 | Chevrolet Cavalier Cars & Trucks
Seat seized possibly something in track because one side works frely
Thiers gearboxes and clutches, in the seat base it's not really designed to be repaired and the best way to fix it is ti buy a used seat base at a salavage year and even on Ebay. Most Gm seat bases are nearly tyhe same as long as the model year is close as the same seat base fits alot of different vehicals. the manual seaty base will also fit if you want to do that as it'll fit too as long it's from about the same vehical. The salavage yards use a Hollander catalog that lets them figure out what willl work. The power and manual seat bases interchangwe as the same vehicals are made both ways. Some times you can get the seat base to go back together, like a cable came out of it's holder but once they start giving troble repaired ones mostly don't stay repaired very long. New ones are expensive and The Dealers don't stock them. I used to work in a rent a car place and peaple would rent one for a day and come back and say the seat wasn't working right and it was'nt even installed all the way. They just rented the car to take the seat base but their was no way we could prove it.
Jun 21, 2011 | 2004 GMC Envoy
Makita Model Dcs 6421 Chainsaw With 20" Bar & Chain - MKA DCS6421 20 Logo
254 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
