Question about Samsung SyncMaster 1100MB 21" CRT Monitor
SERVICE CODE Hello,My monitor Samsung 1100df is very bright,and not a good contrast.To adjust the contrast and brightnes from 0,i must have the service code,to start adjust from the begining 0GreyscaleBrightnes=0contrast=0To do this,i must power off,then press the menu button continuously and press power on.But here is a password *****.What is this pass number to access the menu ? thanks,with best regards,Reuvenreuvenshb@bezeqint.net
SOURCE: default settings on service menu
how do you acess the service menu?
Posted on May 01, 2008
SOURCE: problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Posted on Feb 15, 2009
revskank
  • 203 Answers
SOURCE: monitor settings
is this lcd?
are they frozen or has your backlight gone?
shine a torch on the screen and if you can see everything again, your backlight needs replacing.
Posted on Mar 02, 2009
  • 103 Answers
SOURCE: screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Posted on Apr 05, 2009
  • 259 Answers
SOURCE: Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Posted on May 13, 2009
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Samsung monitor service
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2014 | Samsung S24B240BL 23.6" LED Monitor...
Settings brightness
Hi which monitor are you using? Connect a different monitor to same system to see if that monitor works correctly with that CPU with same settings or connect your monitor with another CPU which is working properly with different monitor to pinpoint exact problem first. Any monitor if gets old will have such problem. If monitor is okay then you can check if display driver is present or not by going to See how many output connections your monitor has if it has multiple input connections like display port, HDMI, DVI, etc, you can try connecting to different ports if your CPU supports to see which connection gives what type of display.
https://youtu.be/lOT4zLqMOWQ
This video has partial information about display settings. You can right click on desktop and select properties and make it to default settings.
Dec 19, 2017 | Samsung SyncMaster P2250 22 inch LCD...
I have AcerPower Series Desktop PC with AC713 Monitor. My problem is in the middle of the screen BRIGHTNESS with 0% of its adjustment go on displaying which hampers my work. Even it's not able to...
Good day,
It seems your monitor is the problem maybe the button is stuck or something. Try bringing it to the nearest service center.
Tnx.
Aug 18, 2011 | Computers & Internet
I need the picture settings for a trutech tv. For example : number for contrast .
Hello
The picture setting for any TV depends upon the taste of the viewer. Contrast is the deepness of details in black and grey level. In most TVs a 55 to 75% of contrast will give a good picture. you have to adjust the brightness level also according to contrast. It is best ot turn out colour to 0% first. Adjust contrast and brightness to get a well detailed B/W picture first. The apply enough colour to that B/W picture according to your taste. Face colour of a newsreader at studio will be the best reference to intensity of colour.OK.
Jul 06, 2011 | Televison & Video
Screen settings
You want to recall the factory settings. There should be an entry in your menu for this. Sometimes its clearly indicated as 'reset' sometimes it is a word that means much the same, such as 'recall'.
The numbers you posted that have a 'K' at the end are settings for the white color temperature. This is an old label from the early days of TVs. One is better than the other for graphics vs clarity. Usually you want the higher setting.
Other wise, if you can't locate the reset option. Go into each setting for Contrast, Brightness and set Contrast 50 and Brightness 100, the others affect the position of the display and how square it is. Set all those values for trapazoid, etc to 0.
Anything else you need clarification on please comment back and I will validate or correct your instincts on what is the reset option command if you are unsure about what is being displayed.
Regards,
Worldvet
Jun 08, 2008 | Acer AC713 17" CRT Monitor
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Samsung SyncMaster 1100MB 21" CRT Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
