Question about RF Link Avs-5811 5.8ghz Audio & Video Transmission System ir Repeater
Set up rf link
Setting up rf link avs 5811 Transmitter is to be connected to a secondary small dvr Direct TV box w/o any outputs. I used a splitter to direct satellite input to an rf modulator. Connected yrw outputs to Rf tranmsitter. Connected receiver to another tv. No signal. My main dvr has yrw outputs, but they are connected to my older tv's yrw inputs. Any help?
  • Patricia Kelly
    Patricia Kelly Mar 25, 2014
    The Rf link transmitter connects to a set-top box via an rca cable and the tranmsitter. My set-top box,in this case the secondary direct tv dvr, has no av outputs. So, I connected a splitter to the coax input line, and connected the coax to an rf modulator with an av output. I connected the rca cable to the rf link transmitter. The rf link receiver is connected to a tv's av input via the rca cable. The transmitter and receiver are about 30 feet apart and there are no walls in between. I cannot get a signal. Hope that this is enough info to help solve the problem. Thanks.
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
How do I find a video to hook up my Samsung TV? Model BN68-04027A-03 The TV was a Xmas gift and did find a video and now I can't find it Tx. Wanda
The English owner's manual for the part number listed is available at...
http://www.manualslib.com/manual/146620/Samsung-Bn68-01171b-03.html#manual
Page six (6) indicates the back panel of your Plasma TV has two HDMI inputs, one component (RGB) and a specialized AV input/output connector. The latter requires a cable that is popular in Europe. Adapters to use it with US standard S-Video and RCA composite video are difficult to locate.
HDMI and component cables are available at big box stores (Best Buy, WalMart etch) but are much cheaper from generic internet sellers.
I am not sure about the second half of your question concerning "get to channel 3 to get to all other channels).
I must assume you have told the TV to "scan" for other channels (cable or over the air (OTA) with the black antenna/RF cable connected directly to the back of the TV.
If you have done so I am guessing you have connected the antenna cable first to a RECORDER or CABLE BOX. In many cases, these will only output channel 3 or 4 and block all other channels when turned on. In order to see other channels, you will need to buy a 2-way RF splitter so that both the recorder or Cable box can be connected at the antenna cable at the same time. Please note, doing so will mean you cannot see the output of the recorder or cable box on channel 3 or 4 but must use its the video/audio (HDMI, component, composite, S-Video) outputs from it to the TV. Again, this splitter is available from big box stores or the internet.
Jan 05, 2015 | Samsung Televison & Video
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
CAN I connect 2 tvs.to one converter box and how.
If you're using a box that has an RF (antenna) output on channel 3 or 4 to the TV, you can insert a splitter and feed two sets. A splitter looks like this:
It takes the signal in on the single connector side, and splits it between the two output jacks on the other side. You can find splitters at TV retailers, Radio Shack, and even at Home Depot or similar stores in the electrical section. Run a cable from each of the output jacks to the antenna connectors on the two TV sets. Each TV will need to be tuned to the converter box output channel, and both sets will get the same program (whatever channel you have selected on the converter).
If the converter box has audio and video output jacks and the nearest set has an AV input, you can connect that set with the same kind of cable you use to hook up a DVD player (RCA plugs on the ends) and select the AV input to see the converter box signal. You would run a cable from the RF output connector of the converter to the second set's antenna jack. Then you wouldn't need the splitter, and the set using the AV inputs would get better quality picture and sound. Again, each set will get the same program as determined by the converter.
Hope this is what you need to get going. Thanks for using Fixya!
Dec 17, 2010 | RCA Analog (RCA) to Digital (VGA)...
Can u explain how to set up the television system with my digital television box.
The digital box should have a round threaded output connector on its back panel. These are usually marked "OUT TO TV" or "RF OUT" or something similar. There may also be a slide switch nearby to select channel 3 or 4 output to the TV. On some boxes the output channel selection is through and on-screen menu. You only need to connect the output of the digital box to the TV's antenna connector, then tune the TV to channel 3 or 4 depending on the box setting. Leave the TV on that channel all the time and do your channel changing on your digital box using its remote control.
If your TV has an AV input for connecting a device like a VCR or DVD player, you can probably connect the digital box that way. Most boxes provide stereo audio and video outputs, and you will get a clearer picture and sound if your TV has the input jacks. If your TV is not stereo and has just a single white input jack for audio (instead of red and white ones for stereo right and left), you'll need a Y-adapter to join the audio outputs from the box together to feed into the TV.
On the off chance you have a digital box with no RF output (I've never seen one since they need to work with older TV sets, but I don't know evey model), and your TV doesn't have AV inputs, you need an RF converter. The converter takes the audio and video signals from the digital box and generates the channel 3 or 4 TV signal that your set can pick up with its tuner. You can find RF converters at larger retailers and online.
Dec 12, 2010 | Disney 13" TV
When hooking my direct tv into the coaxl in it does not work ? When I use the AV cables it works. and I do try all inputs.What can I do
If the coax RF OUTPUT cable of the direct TV BOX is set to channel 3, the the TV will have to be SET TO TV CH3.
Nov 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
RF Link Avs-5811 5.8ghz Audio & Video Transmission System ir Repeater Logo
71 people viewed this question
Top RF Link Computers & Internet Experts
David Payne
David Payne
Are you a RF Link Computer and Internet Expert? Answer questions, earn points and help others
