Question about Take 2 Interactive School Tycoon for Windows
Unexpected error 13:6
I just downloaded the game i actually bought it online and after it ask for the verification code i click finish and says "unexpected error 13:6" ive already tried uninstalling and then installing again
Verify security
Fix Mail Apps and Devices Show Incorrect Password Error After Enabling 2...
[Fix] Mail Apps and Devices Show Incorrect Password Error After Enabling 2-Step Verification in Microsoft or Gmail Account "2-step verification" is an important security feature which protects your online account whether its your email account or a social networking account. It asks for an extra security code each time you try to sign in to your account. This security code is sent to your registered mobile phone or alternative email ID.
Recently Microsoft enabled this 2-step verification feature for Microsoft accounts which are used for emails, Windows 8, XBox, etc. On the other hand Google is already providing two-step verification in its Gmail service since long time.
If you enabled 2-step verification feature in your Microsoft or Gmail account, you might be facing a weird issue. If you try to access your email account using an email client such as Windows Live Mail, Thunderbird, Microsoft Outlook, etc, it'll now allow you to sign in using your current password. It'll show you an incorrect password error message even if your password is absolutely correct. The same problem will also occur if you try to sign in using your Microsoft account in devices such as Xbox 360 or Android smartphones.
Now the question comes why does this problem occur? Why do these mail apps and devices not accept your correct password? The answer is very simple. These mail apps and devices were not designed to ask you for the extra security code which is required for 2-step verification. Since these apps and devices don't ask for security code, the 2-step verification procedure is not completed successfully, hence you can't sign in using your credentials in those apps and devices.
So what's the solution? The solution is very simple. Every company which provides 2-step verification feature, also allows you to create special passwords for these mail apps and devices. You can create separate passwords for each app and device and then you can use that special password to sign in to those apps or devices. Now those apps and devices will accept the new password and will allow you to access your account without any problem.
So if you have enabled 2-step verification feature in Microsoft or Gmail account and if you are facing login password problems in mail apps or devices, you just need to create above mentioned special passwords or codes to sign in without any problem.
Just follow these simple steps to create app passwords for your Microsoft or Gmail account:
A. Create App Password in Microsoft Account 1. Open your Microsoft account security settings page by clicking on following link:
Open Microsoft Account Security Settings Page
2. You'll see "App passwords" section at the bottom of the page which shows following information:
Some apps and devices don't support security codes. In these cases, you need to create an app password to sign in. 3. Click on "Create a new app password" link and it'll immediately provide you a new password generated randomly.
Now you can use this new password to sign in to a 3rd party mail app or device.
B. Create Application Specific Password in Gmail Account
1. Open your Google account settings page by clicking on following link:
Open Google Account Settings Pag
2. Now click on "Security" tab given in left-side pane. Scroll down on the page and you'll see "Connected applications and sites" section at the bottom of the page.
3. Click on "Manage access" button and it'll open a new page showing following information:Some applications that work outside a browser aren't yet compatible with 2-step verification and cannot ask for verification codes, for example: email programs including Outlook, Apple Mail, or Thunderbird, older Android smartphones. To use these applications, you need to generate an application-specific password. 4. Type any desired name in given text box and click on "Generate password" button.create_application_specific_password_google_account.pngThat's it. It'll immediately provide you a new password which can be used in any mail app or device to sign in.PS: If you want to remove or disallow any mail app or device to access your account, you can remove existing app password or revoke access from devices using the same account security settings pages as mentioned in above instructions.
how that helps good luck.
Jul 24, 2014 | hotmail.com
Re: to call of duty wont run in win 8.1
Right click> Properties>Compatability>Run for Windows XP (SP3) or lower
Dec 27, 2013 | Activision Call of Duty 2 for Windows
What is error code 104
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Nov 08, 2012 | Computers & Internet
How can I download a ZYEL G-200 driver to my Dell computer and then pass on to my grandaughters Packard Bell computer that has had the original driver uninstalled
Go here
http://www.nodevice.com/driver/G-200/get47325.html
enter verification code from the image in the box below it, click Download button, when the window appears asking what to do select Save, then select a location (Desktop will do) and wait for the download to finish.
Then put an USB stick in the pc and move the downloaded file from the desktop to the USB stick. Now move the stick to the other pc and double click on the file to launch it.
Jul 12, 2011 | Dell Computers & Internet
Whats the sims 3 registration code?
if you bought the game online and your code got deleted then simply follow these steps:
1) Go to http://support.ea.com/
2) Click Login and use the username & password that you registered your games with
3) Click on My Games
4) It will ask you to Login (again)
5) And ask for your password (again)
6) Click on the My Games tab to see all your registered games
Hope this helps.
Don't be tempted by using a keygen, almost most of them have viruses.
Jan 03, 2011 | Computers & Internet
I bought call of duty world at war for my pc. I bought the game through the download now service gamestop.com offers. The game worked for a while and after restarting my computer I tried to run this...
Hi, Dane You might want to download a different version of the game. Try follow these steps: - Go to http://download.cnet.com/1770-20_4-0.html?query=vuze&tag=srch&searchtype=downloads&filterName=platform%3DWindows%2CWebware&filter=platform%3DWindows%2CWebware and download vuze. It is an application for downloading torrent files. - Go to http://download.cnet.com/1770-20_4-0.html?query=ultra+iso&tag=srch&searchtype=downloads&filterName=platform%3DWindows%2CWebware&filter=platform%3DWindows%2CWebware This is do you can download Ultra Iso to open CD images - Go to http://isohunt.com/torrents/?ihq=Call+Of+Duty+World+At+War and download one of the CD images and then download one of the cracks/serials/unlockers/keygens - Download the files and then open them. if you have installed vuze then vuze should open automatically and the downloads should start - After they have finished double click on the disc image for Call Of Duty( The 6 gig one) and if you have installed ultra iso then the application should open automatically. Click on tools and then mount to virtual drive and then select the Call of duty file and click on mount. Go to computer and then click on the emulated Call of duty disc and then install it(You may want to create a copy of the disc for future use). - Follow the keygen/crack/unlocker/serial instructions on how to use them to allow you to play the game Good Luck hope this was helpful
Oct 29, 2010 | Activision Call of Duty - World at War for...
Error code on start up
hi peter 62 how are you !
  1. You need To Crack The Game
  2. You need To Searsh For The Compatibility Games
  3. And i advise you to download this programmes (atf cleaner, directx 7,gamexp)
and here the Link's
--> Download Link (Direct X 7.0) <--
9148c3a.jpg --> Download Link (game xp) <--
bc4fcd3.gif --> Download Link (Atf Cleaner) <--
__-_-_-_-_-_-_-__
For more information chat me fix-shad0 Thinks °°-°° Rate This Solution when You Can !
Aug 14, 2008 | Gathering of Developers Blair Witch...
Take 2 Interactive School Tycoon for Windows Logo
82 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
Hanzu
EnergeeUK
Level 1 Expert
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
