Question about Whirlpool Dehumidifiers
Motor burn out
Dehumidifier bucket has mold growth in the bucket and now the motor has broken or burnt out. Is this a connected problem or was this the start of the signs of it about to breakdown?
  • Whirlpool Master
  • 3,368 Answers
I think so. I believe the motor failed while there was water in the bucket. Over time the mold started growing, it was consuming the dirt on the inside of the bucket and utilizing the water contained therein.
Posted on May 30, 2014
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
heatman101
  • 43501 Answers
SOURCE: The dehumidifier runs but no water is in the bucket
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
heatman101
  • 43501 Answers
SOURCE: Danby DDR6009RRE dehumidifier bucket switch operation question.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Posted on Jul 13, 2010
SOURCE: What is the best way to remove mold/mildew from
BLEACH & WATER 10:1 solution.
Posted on Sep 23, 2010
What is rightsettingto set at
the general accepted Rh for the avg home is 70% Rh
this is dry enough to not promote mold growth but wet enough that all your wood surfaces wounlt dry out and crack
Oct 19, 2014 | Danby Premiere DDR5009REE 50 Pint Capacity...
How do i know how to set controls on my model 40 Friedrich dehumifier
I would set them to the relative humidity I wanted in that area. You want to keep below 50% otherwise you will eventuially get mold growth.
May 07, 2014 | Haier 45-Pint Dehumidifier
GE Humidifier smells terrible
Probably mold in the collection device that empties into the bucket. Try applying Lysol or similar mold killing spray. This is a big problem with automobile air conditioners too.
Sep 13, 2012 | General Electric 65-Pint Dehumidifier...
Hose is connected to dispose water but bucket fills up
First check that the opening from bucket to hose is clear of obstructions. If you used a washing machine hose and the filter screen is still in the end of the hose, then replace the screen with an ordinary hose gasket.
A gel-like growth can develop in the drain hose. Drain the bucket. Remove the hose and connect it to an outdoor faucet to flush the hose. Reconnect the hose using an ordinary hose gasket.
Oct 05, 2011 | Kenmore 54501 Dehumidifier
There was a hose connected somewhere on the bottom of our Maytag dehumidifier. It was leaking and I pulled it out. Now the indicator light is on and it beeps showing the bucket is full. How can I get it to...
Most likely the drain tube usually a garden hose connector on the condensation tank. My guess is the drain tube has broken free of the holding tank mabe from someone accedently pulling on it? That would explain the "bucket full message"
Take a real good look at the bucket at the rear of the unit see if something there is broken off. You can also look at the end of the hose to see if there is something in there, /my guess is that u need a new condensation collection bucket that will have the connection on it for the hose.
Also please check http://www.applianceaid.com/news.html#recall noticed a possable recall for matag
dehumidifiers
Mar 10, 2011 | Maytag Dehumidifiers
What is the right temperature setting when the room has a lot of water?
You can't control the temperature setting but you can control the humidity level. I would start somewhere between 35 and 40%- making sure to empty the dehumidifier promptly when full. 40% humidity will prevent mold and mildew growth- and that musty smell- but keep the room from becoming too dry.
Mar 01, 2011 | Kenmore 54501 Dehumidifier
heatman101
Apr 17, 2010 | LG LHD45EL Dehumidifier
Bucket full indicator blinks when bucket is empty. Also please recommend setting for a crawl space
switch may be going bad or not making a good connection inside container as far as setting a crawl space will be most damp if your worried about mold would recommend most dry setting
Jan 18, 2010 | LG LHD65EBL Dehumidifier
My dehumidifier runs and over fills the bucket till it runs on the floor
Sounds like it has a bad float switch of some sort. Unplug it and take it apart and see if you can find it. It may just be stuck in a position from some mildew or growth from being around and in water constantly
Sep 20, 2009 | Maytag Dehumidifiers
Dehumidifiers Logo
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
