Question about Onkyo TX-SR304 Receiver
SUBWOOFER VOLUME PROBLEM
My subwoofer has no volume anymore. everything is set at the highest volume but still I get no volume from the sub.
  • 757 Answers
Make sure you have the sub connected to the proper output on the receiver and no connections are damaged.
Then check the gain/level control for the sub. on the receiver...turn it up if it's down.
Make sure that in speaker setup, that you have the selection for a sub turned on.
Posted on Jun 18, 2009
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
Built in subwoofer not working
check for the volume of the subwoofer
see the voume sttings
Mar 28, 2009 | HP Audio Players & Recorders
Adjusting the subwoofer volume seperately from speaker volume
You can't exactly set volume but definitely turn down the bass which lowers the sub's output. Thats all we can do i think.
Mar 12, 2009 | Logitech Z Cinema 2.1 2.1 Speakers
SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Sep 25, 2008 | Sony SA-WM500 Subwoofer
No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Jan 10, 2008 | Sony SA-W305 Subwoofer
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
Subwoofer works at high volume, doesnt work at low volume
You had the settings set incorrectly and overdrove it. The voice coil leads are burn't open. If you look at the little flexible braids by the terminals I'll bet they are black/brown and maybe even burn't in half. It's toast.
Sep 17, 2007 | Kicker 02S10L74 Car Subwoofer
Onkyo TX-SR304 Receiver Logo
219 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
