Question about Stihl Genuine 4241 007 1003 Gutter-B Cleaning Kit
Assemble How to assemble gutter cleaner tube to stay on blower and not be blown off.
    New Friend:
  • 20 Answers
Tape it
Posted on Apr 16, 2014
Gutter attachment for leaf blower
Would that work for seamless gutter? We are going to replace ours and we had been looking into getting the seamless kind cause they looked fairly easy to deal with. It would be awesome if that leaf blower attachment worked for our gutters. http://www.thompsonheatingcooling.net/Seamless-Gutters
Nov 07, 2013 | Husqvarna 560BTS Backpack Blower
How do gutter guards work?
they work like a screen, letting water into the gutter but holding leaves and solid objects outside of it. this allows the water inside the gutters to flow freely without being blocked by these objects
Jan 15, 2013 | Roofing
Can I extend the length of the blower tube on my 125BT blower?
I tried that (once). Used ABS plastic from Lowes to make a custom gutter cleaner, attached to a big ECHO back-pack leaf blower. Several problems: 1) Pipe is heavy, so put a couple of 90 degree elbows on the end to "hook" onto the gutter. 2) Need to wear a rain suit, because of the NASTY decomposed leaves raining down. 3) The air tended to lift the shingles (very bad). I only tried it once and don't recommend trying it. The same idea with a garden hose may work better? Eventually, leaf guards were installed with limited success.
Nov 01, 2012 | Husqvarna Garden
It will start then shortly after running it will stop running
As I was flying by your page, I’ve noticed that you have not heard of a better and safer method of cleaning out your rain gutters. May I please intrude on your privacy and tell you what I’ve seen as I’ve been breezing by? Thank you. Now, you can clean out your rain gutters with a new designed wet/dry vac tool called a “Gutter Clutter Buster” and stay firmly on the ground while you are cleaning. No more worries from me that you are about to fall off that ladder or that you are getting drowned from a water wand or water hose, or that you have debris blowing all over you, into your eyes, your mouth, etc. and your newly cleaned windows and roof from the blower you were using. Now, I can stop for a moment and take a heavenly breath of fresh air as I know you will want to check this new tool out and see how safe you will be while cleaning out your rain gutters the next time. I’ll just have to fly out of here and go on to the next site to see who may need the wind below my wings to get them started again. Bye, bye and fly straight, fly safe, and fly well.
Jul 26, 2010 | McCulloch Garden
It runs for 1 minute and stops. I replaced the spark plug & cleaned the vents.
Jul 25, 2010 | Homelite Consumer Products MightyLite...
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Stihl Genuine 4241 007 1003 Gutter-B Cleaning Kit Logo
69 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
