Question about Bose Corp Bose SoundTouch 20
Will not turn on
The device briefly turned on to start with - had issues in the setup process and now will not turn on at all.
Wont finish its loading process
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Feb 06, 2014 | RCA Tablets & eReaders
Cmp756 memory
I have the same problem....
Nov 19, 2013 | Cell Phones
Setup the wrong language during the initial setup process. Device will not let me go back and correct the issue. Need to know how to redo the language selection part of the setup mode. The device is no...
Press and hold the Play button until the player turns on.
After the Welcome screen the Main Menu will appear.
Press the PREV/NEXT button to select the Setting mode.
Briefly press the Menu mode button to enter the Setting mode in order to view or change the setup of your system.
Select the [EN] icon (the first icon on the first row).
Dec 29, 2011 | Audio Players & Recorders
NEED CODES FOR A SHARP TV AND A MAGNAVOX DVD PLAYER
Hello
There is no specific codes lited in its manual. You can search and find your devices' code by code search method.
Code Search
If the device you wish to control does not respond to any of the codes you
have entered using the Library Code Entry, you can search the entire code
library for a particular device that might not be listed in the Code List or
might be listed under a different brand.
When you enter a valid code for any given mode (e.g., when you enter a
code for a TV), the default key labels are displayed on the touchscreen and
any previously Learned functions for that mode are deleted. The mode is
reset to its power-on default state.
To search for a specific code in the Code List, follow these steps:
1. Manually turn on the device to be controlled (TV, VCR, DVD, etc.).
2. Press and hold the SETUP key on the rubber keypad until the LED
indicator light remains on and the touchscreen shows the Main Setup
Screen. This process takes approximately 2-3 seconds.
3. Release the SETUP key.
4. Press and release the LCD CODE key. The LED indicator light blinks
once to indicate acceptance of the keypress.
5. The touchscreen now shows the Device Setup Screen. Press and release
the device key on the rubber keypad for the device whose code you want
to enter (TV, VCR, SAT, etc.). The LED indicator light blinks once to indicate
6. For AUX1 or AUX2, press the AUX device key. Select the desired device
key to be programmed under AUX (TV, VCR, SAT/CBL, etc.).
7. The touchscreen now shows the Code Setup Screen. Press and release the
LCD SEARCH key.
8. The touchscreen shows the Search Setup Screen. Press the ON•OFF key
on the rubber keypad repeatedly, until the device to be controlled
responds to the command and turns off.
Note: The Code Search starts from the currently stored code under that mode. For
example, if the device code list contains 100 codes and the currently stored code is
050, the Code Search starts from 051 and continues to 100 before looping back to
000 and finishing at 050. This speeds up the process of finding the correct code for
your device, since you may discover some codes can turn your device on and off
but are not able to control its other functions. This process allows you to
bypass codes you've already tried.
Mar 27, 2011 | GE JASRM24912 Remote Control
The process android.process.acore has stopped
please try to reset its because of the software corruption it usually happens in Htc models...
1.Phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
2. Wait for the phone to finish the reset process and then press MENU.
if it does not solve upgrade to latest firmware
Update to latest version
http://www.htc.com/www/support.aspx
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | HTC G1
I turn it on but it never comes on it just shows the t-mobile logo and then starts again and repeats this
I'm afraid you'll have to hard reset your device, in order to get rid of such a condition. To do it, first turn your device off. Then, press and hold both softkeys (the ones marked with '-'), and, whilst keeping the softkeys pressed, briefly press the power button, to turn your device on. Release the softkeys when instructions pop up on the screen. Follow them. Bear in mind that this process is timed out. So, if you miss some step, you'll have to start it over again.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 22, 2010 | T-Mobile Dash Smartphone
It do not open
I think you'll have to hard reset your device, in order to get rid of such a condition. To do it, first turn your device off. Then, press and hold both softkeys (the ones marked with '-'), and, whilst keeping the softkeys pressed, briefly press the power button, to turn your device on. Release the softkeys when instructions pop up on the screen. Follow them. Bear in mind that this process is timed out. So, if you miss some steps, you'll have to start it over again.
Hope you are able to see your device working again.
Cheers! Carlos
Apr 12, 2010 | T-Mobile Dash Smartphone
My HTC Dash phone freezes at start up showing the green screen "Windows Mobile". How can I solve this problem? Thank you
I suppose you'll have to hard reset your device, in order to get rid of such a condition. Do do it, turn your device off. Then, press and hold both softkeys (the ones marked with '-', and, whilst keeping the softkeys pressed, briefly press the power button, to turn your device on. Release the softkeys when instructions pop up on the screen. Follow them. Bear in mind that this process is timed. So, if you miss some step, you'll have to start it over.
Cheers! Carlos
Apr 07, 2010 | T-Mobile Dash Smartphone
Bose Corp Bose SoundTouch 20 Logo
35 people viewed this question
Top Bose Corp Audio Players & Recorders Experts
Tom Chichester
Coss
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Bose Corp Audio Player and Recorder Expert? Answer questions, earn points and help others
