Question about Fuji FinePix S700 Digital Camera
My Finepix s5700 will not turn on even with new batteries. The last thing I did was delete some photos from the memory card. The next time I went to turn it on I thought the batteries were dead and so I replaced them with new ones, but it still will not turn on. And the camera was not dropped.
  • 244 Answers
A possible cause could be the "cut off" switch for the xd picture card door. Check the plastic tabs on the door for damage. If it looks ok then open and close it a few times to see if the micro switch on the board is stuck. This is a cut off switch to prevent accidental removal of the picture card whilst the camera is powered up. The battery door may have 1 aswell so best to check this also. If there is damage then you maybe able to effect a repair to the plastic tab or replace the door. if the micro switch is damaged then you can bypass with either a solder bridge or wire. Have you put the batteries in correctly? - just an after thought....
Posted on Jun 14, 2009
  • michaontour Apr 07, 2011
    I have the same problem. The light for the power goes on for half a second and turns off immediately. The cam does not turn on. batteries are in right order, card reader door is closed properly Any more tips?
    Cheers,
    I just figured out, with AC it runs, but not with batteries. They are fully charged and it still does not turn on...
I recharged batteries on 4 month old Finepix4000 and it wouldn't turn on. Yes, batteries in the right way round, uncorroded, terminals OK etc. No joy from Fuji site other than 'post it to us for repair'! Flagged the issue up on some forum I can't find again, but discovered the answer by trial and error.
Hold in the +/- button at the same time as pressing on switch. I guess thatre-sets it. Sometimes these buttons need to be held down for a set number of seconds for reset function to work.
Posted on Aug 21, 2012
Downloading from a fujifilm s5700
How did you "erase" them?...on your computer? Have you tried inserting the card into a separate card reader and tried to download that way?
Jul 14, 2010 | Fuji FinePix S5700 Digital Camera
Photos are being saved to internal memory instead of memory card
Remove the card and go into the camera menu and find "format"...follow the on-screen instructions.
Apr 12, 2010 | Fuji FinePix S5700 Digital Camera
Hello, I purchased a finepix s5700 about 18 months ago. It has worked perfectly until the last few weeks. I can turn the camera on if I hold the playback button and switch on the power, and can scroll...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 29, 2009 | Fuji FinePix S5700 Digital Camera
Dont no how to download my photos from my fuji finepixs s5700 to my pc
you can do it either by installing the finepix viewer and connecting the Cam to PC via the USB. the transfer rate is very low. For better transfer rates you can use a card reader
Apr 26, 2009 | Fuji FinePix S5700 Digital Camera
Cannot delete pictures, or access memory
there might some software trouble check using different memory card if nothing works try formating memory card r reinstall the software in camera
Dec 11, 2008 | Fuji FinePix F470 Digital Camera
FinePix s5700 - Memory Full Error
Ok i had the same problem. But what i did is,i removed the memory card used my memory card reader and format the memory card. The i turned the camera on and used the internal memory to take a photo.The i opened the memory slot and reinsert the the memory card and walla the memory full error was gone.
Nov 05, 2008 | Fuji FinePix S5700 Digital Camera
Memory Card problems
It may sound stupid and obvious but try just taking the memory card out, give it a bit of a blow/wipe and putting it back in again, worked for me when my s5700 said it had a full card or that there was some other problem with the card
Jan 23, 2008 | Fuji FinePix S5700 Digital Camera
Fujifilm s5700 camera
Yeah there is a way of getting the photo;s back that you'e deleted from the card.. just don't do anything else like re-format the card and put anything else on it in the meantime.
Try Zar recovery, I'm sure there's a free trail period before having to buy... I've used it and got all my photo's back!
http://www.z-a-recovery.com/download.htm
Next your gonna want to re-format your media card, this should be very simple.. go to my computer and right click on it and go to the option format; then format the whole size of the storage media as "FAT"
Hope this all works okay for you
Dec 10, 2007 | Fuji FinePix A350 Digital Camera
Transfer from internal memory to new memory card
Go to Playback Mode (with memory card inserted)
Press Menu/Ok (center botton)
Copy
Internal Memory to Card
Then choose "All Frames" or select which ones
Sep 21, 2007 | Fuji FinePix S5700 Digital Camera
Fuji FinePix S700 Digital Camera Logo
851 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
