Question about Indesit IS70C Electric Dryer
Knocking sound my dryer is making a knocking sound as the drum turns. it seems to quieten down somewhat after it has run for about 10 mins.
    Sergeant:
  • 446 Answers
Drum rolls
Posted on Mar 24, 2014
Dryer runs for about 10 to 15 min and stops
Reach inside and turn the drum. If it seems hard to turn you might have bac glides. Common probo for GE dryers. I recently replaced some giles on a dryer and took the time to photo the method for replacement.
Jan 14, 2014 | Hotpoint Dryers
Drum turns, getting humming noise after running for short time.
You will need to check the drum rollers. Sounds like one or more may be failing. Here is a link to the part.
Here is a video to show you how to make the repair.
Oct 16, 2012 | Frigidaire Dryers
When the dryer starts it makes a quick grinding noise like it is having trouble starting. After only 1 second that noise goes away and the dryer appears to be working fine. It will stay running anywhere...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Whirlpool LER4634J Electric Dryer
Drum is making a lot of noise after it runs for 10 min.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 06, 2011 | Amana DLE330RAW Electric Dryer
I have a kenmore 90 series dryer model 110.60922990. It makes a funny noise while running for a few min. After about 10-15 min it shuts off and will not restart immediately, I have to wait for a few min...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 06, 2011 | Kenmore Dryers
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Cuts off makes noise
Sound like the dryer bearing or rollers are out. This would make it very hard for the dryer to start and run. You must pull the dryer drum out to access the parts. I'm sure you will see the problem right away once it is apart.
Apr 01, 2010 | Whirlpool LER5636P Electric Dryer
Dryer makes screaching noise as the drum spins once the dryer is running for 10 min or so. Sounds like the drum needs some WD40.
bad roller or pulley or depending on the dryer like frigidaire there is a bearing that goes on them and will make that noise,next time send brand name and model number
Nov 05, 2009 | Dryers
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Indesit IS70C Electric Dryer Logo
Top Indesit Dryers Experts
Tim Whalen
Gerard Curran
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
