Question about Keurig Coffee Makers & Espresso Machines
Keurig K10 water spills out top and sides while brewing
Have tried clearing the needles and descaling with vinegar but water continues to spill out of the top and sides during brewing.
    Problem Solver:
  • 14 Answers
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Posted on Apr 20, 2014
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
mcdevito75
  • 1970 Answers
SOURCE: Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Posted on Jun 20, 2010
heatman101
  • 43501 Answers
SOURCE: First time to descale coffee
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Posted on Feb 23, 2011
heatman101
  • 43501 Answers
SOURCE: How do I do a
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 31, 2011
How do we descale our Keurig coffee maker
Fill the water tank with vinegar and then brew a cup a coffee using nothing but putting lever in brew mode.
Repeat several times, then fill water tank with clear clean water and repeat brewing process until no vinegar taste remains.
I have used my Keurig for years and never had to de scale.
Are you sure it needs it.
If this is a continuing problem suggest a portable reverse osmosis unit and use water from it Vs your tap water.
They can be had on ebay for under $100 and are easy to install. Coffee tastes better too.
May 25, 2017 | Keurig Coffee Makers & Espresso Machines
Keurig B150 - continuous water dispensing
Their appears to be a scale build up inside the valve that dispenses the water when demanded. This is an electrical solenoid much like in fridge water dispensers but smaller. The scale is not letting the valve close completely after dispense. On a regular brewer running vinegar thru the machine a couple of cycles will usually dislodge the obstruction in the valve. If you can manually add water to the brewer, you should add the vinegar instead to clean the valve. Otherwise you may have to disassemble locate the valve and soak in descaler, or vinegar.
Jan 11, 2015 | Keurig Coffee Makers & Espresso Machines
Kureig heats but won't brew
The exit needle could be clogged located( inside bottom of the holder assembly). Remove K-cup assembly and detach funnel. Insert a paper clip or simiilar tool into the exit needle to loosen the clog and push it out. REMEMBER, the needles are very sharp, proceed with caution!!
You may also need to Descale your Keurig...I do this every other month due to high mineral content in my potable water. Change out resevoir filter and clear exit needles as part of Descaling. Disable "auto shut off" feature, remove reservoir filter and do not use a kcup prior to proceeding. Place 48ounces of white vinegar into reservoir, press brew, discarding each mug of water down kitchen drain and repeat until "Add Water". Let brewer stand for four hours in "On" . Rinse after 4 hours by filling water reservoir with fresh water and press brew until ADD WATER is indicated.
I run two full fresh water cycles before actually using the Keurig for beverages I will consume.
Hope this helps
Nov 17, 2013 | Keurig B60 Coffee Maker
I have a Keurig Vue. I have descaled and cleaned the product on schedule but it leaks water from all around the brew head and only 5-6 oz of coffee make it into the mug. I tried to clean out the pin also...
Remove and clean the Brew Head, with the V700 the way to remove would be to open the lid with the handle, place your fingers around the Brew Head, there are tabs to each side, press tabs and pull down and toward you. Wash this out thoroughly in your kitchen sink. Now before replacing the Brew Head, with the handled lid up, turn the back of the brewer so that it is facing you...Look straight down into the top of the brewer, you will see the needles, use an old toothbrush to clean them. Replace the Brew Head and descale the brewer with White Vinegar (do NOT dilute with water) or Keurig descale solution (purchased only through their website). The video to watch the descale instructions is: www.keurig.com/customerservice
Hope this helps!
Oct 28, 2013 | Keurig Vue V700 Brewing System - 110774
My Keurig is not drawing water from the reservoir and it flashes "de-scale" on the screen. I don't see a way to disassemble the machine to descale it.
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Sep 14, 2010 | Keurig B100 Coffee Maker
I have the Platinum Keurig, but it will not take in any water from the tank. I've tried to descale, but if it won't take the vinegar solution, what else can I do?
Sep 12, 2010 | Keurig Platinum B70 Coffee Maker
Mar 25, 2010 | Keurig B60 Coffee Maker
Keurig Platinum is clogged
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Apr 04, 2009 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
220 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
