GPS tracking system for vehicles can be of two types, depending on whether you need the vehicle position in real-time, or do you need the vehicle tracking data after the vehicle has travelled. Based on the requirements, there are two types of vehicle tracking that are available. They are:-
Active: The active GPS vehicle tracking devices are used to transfer the positioning data real-time to a close range wireless network device, like a phone with a Bluetooth.
Passive: Passive GPS vehicle tracking devices do not transfer the data real-time, but stores them for later use.
Thanks for using FixYa. Please install the PC suite to connect it with your computer and transfer the numbers to the Computer. This software also contains the connectivity drivers for your phone with the computer. Please click on this link to download the software--
There are two ways you can solve your problems...First by formatting the player using your windowsmedia player and second by updating the firmware on your device.To upadte the firmware go to the sandisk site or you can contact sandisk so they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
go to contacts and pree options and then press copy - and chose from sim to phone
if u dont have this option in the phone so u need to take to the store and they will copy it by cellebrite
There are 2 reason why you would get that error..
1) when you transferred the tracks to the device the licenses didnt transfer...
2) The tracks you transferred are subscription tracks meaning that you have to sync your device each month in order to have those tracks playing...
If you dont have a subscription for the tracks...(you will have to format your device in that case) and also you could have a device certificate problem which can solve by formatting your device or your DRM components maybe bad...you can solve that problem by foramtting updating the firmware on the device..
If you have a subscription you need to download a new track and transfer it to the device again...that should update the licenses for every single tracks...If that doesnt do it you will have to format your device...
I hope this helps...
There is a problem with a corrupt file. it seems as though it is playing tag between your computer and sansa. clean up the computer and erase everything from the sansa, restart/reboot everything then try it again. if the problem continutes then it may be the motherboard, but please note that the motherboard would not mess up your computer. if it is under warranty, send it back.
Thanks,.....Connie
