Question about Alesis DM6 Electronic Drum Set
My snare and rim hits randomly when I hit the high-hat? Can I turn the sensitivity down or do I need to do something else?
The snare and rim show a hit randomly when I hit play which is very annoying I have tried moving the snare in case it was catching but it still happens any help would be great
4 Suggested Answers
  • 5603 Answers
SOURCE: i have the dm10 studio
Realize first that your "instant" is like eons to the electronics where billionths of a second count... This is an interesting set of symptoms. I would connect one of the other devices to one of the tom inputs and see if the snare acts the same using that devicee. Also try to characterize how much ahead or behind the snare hit the tom hit can occur and have both sound. This problem MAY be embedded in either the electronics or the firmware in the module. It could be an electrical noise issue or any of several other things. I want you to try this using ONLY headphones and NO amp... this is to isolate the possibility that the vibrations of the snare by the amp may be triggering anti-noise gate in the snare circuit. These are some more tests I want you to do the above and give me the results.
Posted on Sep 13, 2011
miltonmagalh
SOURCE: When I hit the snare
I believe I have found a good part of the solution to this problem. I also had this problem in the snare. The problem was so severe that, when pulled, the snare support, without giving him any beat, the sound appeared. I took courage and opened the snare.Ao open, I realized that a yellow adhesive used to glue the trigger wire had melted and the other touching the trigger. I think this must have happened at some point prior to my purchase that equipment has been under excessive heat and then drained to such a glue. Simply cut the little wire glue "connected" two triggers, and closed the snare ....... ready: is working perfectly.
Posted on Sep 01, 2012
iricad
SOURCE: The snare triggers incorrectly
hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly).
I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
let me know
ciao
Posted on Oct 13, 2012
Testimonial: "It worked on my second try. Thanks a lot!"
I have the dm10 studio pro 2011 kit, and no matter how i store settings for priority, if the rim of tom 1 or 2 are struck at the same instant as the snare head, the snare does not sound. even if i set no...
Sep 13, 2011 | Alesis DM10 (Module) High Definition Drum...
Where does hihat control cord go
The hi-hat trigger goes into trigger #1. Using a footswitch will change the hi-hat trigger sound to a closed hi-hat. On page 8 of the user manual is the list of triggers and their assignments. Note that some new triggers from newer drumsets use TRS cables because they have two sensors within the drum head... Often the new ones have a rim shot snare trigger as well as a trigger for the mesh head. These newer different brand triggers would require special cables to be made to attempt to use them with the DM5. The DM5 is older technology now but is still useful.
Jul 25, 2011 | Alesis Dm5 Drum Module 18 Bit
I have a TD9KX and the problem i get is right in the centre of snare the sound seems to overload or is too sensitive. I cant get rid of this even when adjusting sensivity.
If the drum set is older, the cone that is in the center that transfers the hit to the piezo is degraded. You can find replacements on Ebay. You have to remove 4 screws to get the bridge under the snare out and then peel off the old cone from the piezo disk CAREFULLY and then stick new one on. The point of these goes bad. You will then want to adjust the height of the cone with the adjuster screws so it is barely, barely touching the drum head.
May 15, 2011 | Roland Elektronische Musikinstrumente...
Two of the pads on my Yamaha DD55c drum machine do not seem to be triggering properly. For example, if I hit the snare pad it seems to always be triggering at a low velocity, but if I strike it flat with...
A weak snare is a characteristic of these... The triggers are typically piezo discs that were often used in musical cards but those have now gone to using very flat little speakers... You may find some have been dislodged or broken loose... worth a look inside.
Apr 11, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Mar 27, 2011 | Simmons SD9K Electronic Drum Set
When I hit the snare drum harder than usual, it is making a different sound. Is that supposed to be?
Mar 15, 2011 | Alesis DM6 Electronic Drum Set
You can not play these drums live the spill of the fold back drum fill bin sets of the snare trigger ive turned down the sens on the red box still doesnt work a big waste of money i need to talk to...
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Hope that helps!
Feb 11, 2011 | Pearl E-Pro Live Electronic Acoustic Drum...
Every time i hit it anywhere on the front the snares shake, whats wrong?
Absolutely NOTHING is wrong. The snare drum resonates. The only solution is to NOT let th snare drum "hear" the Cajon... This is a common problem... Other instruments can also trigger the snares... SOME people add clearance of the snares to the drum to avoid some of the problem.
Jan 10, 2011 | Toca Cajon Bordeaux
Alesis DM6 Electronic Drum Set Logo
27 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
